Steam from Right Front
Drove my E63S home last night in dry weather. No issues. Drove it for 2 hours today in steady rain. When I parked, lots of steam poured out of the right front. Definitely steam. Did not smell like coolant. The front facia above the right front radiator/intercooler area was warm. Does anyone know if the oil cooler is on that side? Or is it a hot side of intercooler? I hope it is just accumulated rain water flashing off of hot pipes. Any thoughts?
VIdeo here:
VIdeo here:
I noticed it too at the beginning even after 5 minutes of driving. Strange that I haven’t noticed it anymore. Or maybe I don’t care as much lol. It’s likely water dripping into the radiator vent. Doesn’t affect engine temps or anything. Lots of HP means lots of heat! Steam looks badass too.
64stingray (12-01-2018)
2024 AMG EQE SUV , 2021 E63S Wagon - gone, 2018 E63S Sedan - gone
[QUOTE=64stingray;7618203]Drove my E63S home last night in dry weather. No issues. Drove it for 2 hours today in steady rain. When I parked, lots of steam poured out of the right front. Definitely steam. Did not smell like coolant. The front facia above the right front radiator/intercooler area was warm. Does anyone know if the oil cooler is on that side? Or is it a hot side of intercooler? I hope it is just accumulated rain water flashing off of hot pipes. Any thoughts?
VIdeo here: https://youtu.be/yOzqvsd6-u0[/QUOTE]
Sounds like misaligned rubber molding under the hood letting water through where it should not go. I just came into the house from a heavy downpour into the garage and saw NO steam when I finished parking. Doesn't sound good to have water dripping on parts that should be dry.
The following 2 users liked this post by HBerman:
64stingray (12-01-2018),
mmmamg (12-05-2018)
The reason that that area is warm is that is where the coolant expansion tank is located. The steam could be a sign of a pressure leak in the area. Again, I have never seen any steam in that area and there are not any pipes or metal that should be getting hot for steam generation from rain water.
Has this car washed two times so far. Both times there was a significant amount of steam coming from the right side. I guess you can say it’s coming from the right side intercooler guard area. Below the headlight. No smell or anything. The steam continued during the entire wash.
64stingray (12-13-2018)
It is supposed to rain all day Saturday and I am driving from Western Maryland to Wash DC for a Capitals game. I'll post what I observe. I wonder if I had/have a drain hole blocked?
I just got off of the phone with the service manager of my dealership on another matter. I mentioned your observation of steam and he said he has never heard of that or seen it on any 2018 E63S. It's certain that water is hitting some hot metal, but perhaps that is happening due to misalignment of under hood moulding or water backing up and not draining. I'm curious about this so please report back.
64stingray (12-14-2018)
So I had to run into work this evening -- approximately 20 mile round trip -- 15 minutes each way in the rain. Just parked it in the garage and steam is coming out from the same area. Identical to original videos I posted. I did ask my dealership's service manager and he said they have seen this on the twin-turbo cars. I am going to make sure I stop by one day when it is raining to make the see it so if some damage does occur, its noted as a latent defect.
sjb -- my opinion is you are misinterpreting. HBerman and I were swapping observations. While many are seeing this, not all are seeing this. From an engineering perspective, that makes me question "what's different" with the cars that are boiling rain water off of hot parts.
I can't say for certain but I don't think I have seen the trans temp go above 200F. I will look. I've been scanning the service menu (left instrument panel screen) and have not observed anything unusual. There is another storm coming up the coast so I will have another opportunity to troubleshoot.
Enjoy the holidays. It's good that you've determined that your intercooler temps are in a normal range.
64stingray (12-22-2018)
C63 W204 / E63S W212 / E63S W212
Thats normal, i believe it does it only on one side because one of the auxillary coolers is hooked up to the main coolant line which cools the block therefor running hotter than the aux cooler on the left. In that case left aux cooler should be hooked to the Intercooler coolant line “low pressure circuit”, which runs cooler. In the w212 ecu would target ic coolant temps of around 100 F, not sure whats the target temp on w213 but shouldnt be too far off i assume.
64stingray (04-26-2019)
