USA Gas
USA Gas
Hi guys,
I come from Canada Quebec.
When I put gas to my car, I always use 91 which is the maximum in Quebec. I mostly try to go to Shell to buy V Power which in my opinion is the best gas. 91 octane in Quebec has no ethanol.
Anyways, here in Florida, I am putting 93 Octane but every gas station mention that it has 10% ethanol. Why????
Is there a gas station that has no ethanol?
Hi guys,
All you'll get is E10 across the US with 93 octane being mostly available all over except the West Coast. You can search for a non ethanol gas, just came across this site https://www.pure-gas.org/index.jsp?stateprov=FL Can't vouch for the accuracy. All I put in my wagon is 93 E10 in NY, car can handle it & no issues so I really wouldn't go on a hunt for non ethanol gas IMO.
Benefits of Ethanol: The Environment, the Economy, and Oil Dependence. Overall, ethanol is considered to be better for the environment than gasoline, and ethanol-fueled vehicles produce lower carbon dioxide emissions and the same or lower levels of hydrocarbon and oxides of nitrogen emissions.
W123 300CD, R107 560SL, W211 E320
Some of our local WaWa stations here in Virginia sell ethanol-free gasoline. It is priced higher than Diesel. Outrageous to pay more for a fuel with less additive in it.
we have non-ethanol gas stations here in WA too, but the price is $1.5 over than gas with up to 10% ethanol... Can't see any reason to use it.
you can find ethanol free but costs more due to not having subsidy.
I use ethanol free in my lawnmower and other small engines (2 and 4 stroke) to make them last longer as they were not designed for ethanol in fuel.
I am pretty sure that the 91 gas I put in Canada is Ethanol free. I looked it up. Specially the V-Power from Shell in Canada is Ethanol free Plus it has detergents to clean up the engine. It is almost the same gas used in the F1,
Related and additional Qs... I see the requirements for 91 Octane gas. If i can get 91 and higher options here in Germany, should I be consiconsistent at 91 or get higher when I can? I don't want to be cheap but also don't want to waste $ or AKI. Also is there any concern running 93 or higher here and then having to go back to 91 anyway depending on where I bring the car back to in the U.S.?
Gotic4u (12-30-2018)
Thanks Mandarin, Right we use RON here in Germany but it still has a AKI or octane equivalent that I already converted to U.S. as I posed the Q. We can get 4 different RONs and the highest two are RON 95 and 98. (95 RON = the 91 Octane or AKI that my US spec E63 needs or requires). The question I would like input on is whether most of you would buy the 98 RON (94 AKI or Octane because you can)? I don't mind doing so, but also wonder is it worse to make the car go back to lower later if we go back to a place such as CA... I also realize the computers make up for these differences in octane best they can, but this is my first experience with a MB - let alone an AMG... Just want to follow the experts on this forum. Thanks all!
I’ve had multiple Euro deliveries and drove more than 10k miles in Europe with highest octane available. Cars were properly trained on the autobahn and none of them had any issues running lower octane in CA.
As long as you don't use lower than 91, you should be fine. Very important to find gas without Ethanol tho because that's the big issue.
That said MB is made to handle it and not a big deal.
I've been using e98 in my carbureted snowblower for 2yrs. Same container, I bought the fuel in 2017. Works fine. Main differences:
1) no exhaust fumes.
2) Machine has to be kept indoors because it won't start if it's left outside in -20 weather.
3) I have to pull the choke lever a little bit so that it runs right.
It's possible that an older machine might have had problems when switch to ethanol if impurities have already built up. Mine was only one or two years old when I started using ethanol
