2019 E63 S feeling... slow?
I picked up my car late November. It's really weird, every once in a while it feels like a freaking rocket! But about 60% of the time I'll step on it and wonder what's going wrong. Always in sport+ mode with the a/c off. Has anyone else experienced this?
Try Shifting the gears you're sells. If you're not in the boost and in the right place in the throttle band then that could be it. Cars these days always hunt higher gears even in sports+ if you haven't given it some gas in sometime.
TimHayes63 (12-28-2022)
s26singh (01-14-2019)
I've noticed the same thing on my 2018 wagon and it only seems to happen when I'm trying to impress the passenger. One theory is if you just did a manual gear change and then floor it, it would not kick down correctly.
go fast grocery getter wagon
Could it be that we are pretty well have gotten used to the power output already (while our butt dyno is expecting more) I have certainly felt this way this past few months too
I can only assume it is that, I’m actually going to get mine tuned after it’s first service!
bobblehead (01-14-2019)
2022 Mercedes EQS 580
Sounds like a loose hose. Maybe the exhaust waste gate hydraulics.
BTW I had this issue and it was a bizarre root cause.
The radar detector equipment had come loose and the wires were moving around and sometimes falling on the arms of the throttle and brake pedals, which was causing light occasional light application of brake pressure depending on where the wires fell while applying the throttle and causing lag. The dealer quickly diagnosed the issue, relocated the radar detector wiring and securely tied it up. Problem solved.
I personally get afraid driving this car. It's "lose your license" material just... so quickly. You don't even feel it. I kind of wonder if highway patrol could keep up?
Hnic91 (12-29-2022)
Nice! I’m going to get my first service done and then getting the MSL guys in the UK to do it, they have an amazing reputation and as seen in another thread, some pretty good results.
I'm probably being dramatically over-simplistic but I have a strong feeling that pretty much every tuning company that is currently around does nearly the same things for a stage 1 tune. At a high level, the power increase results seem about the same across the board.
iIt’s not as big a market in the UK as it is in the US and for me, I like to know the people I use have a lot of experience and proven results.
Received 1,886 Likes
2014 E63S; AMS 100 octane ecu tune; edok tcu tune; BB intakes; dyno tuned
There have been hose associated boost issues, agreed
you may have a legit mechanical problem
Thanks everyone for the input! I'm going to get my 1,800 mile fluids changed in about 2-3 weeks.
I'm having them put on the MPS4S's I just received and have them check into the hose issue. These Pirelli's have got to go. They're brand new so they're not that bad yet. My previous car came with them and I started hydroplaning at 45mph after about 4k miles on them. I don't want to experience that again.
I did find that when I manually downshift about 2 gears before punching it, my passengers grab the "oh sh*t" handle a little tighter. Lol
Also, I'm about 45 minutes south of Stuart, FL. I contacted Renntech about tuning my MY 2019 and they said they're about 6 weeks away from finishing development for this model year. I guess there's minor differences in the software? I'll create a post reviewing the tune via butt dyno after.
PLATINUM SPONSOR
Big difference in power between warm days and colder /higher barometric pressure days; if that is what your feeling.
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
www.ultimatepd.com
2018 mercedes E63S AMG W213
I have a 2018 E63S w213 and i am having the same problem after installing downpipes picked up my car and all of a sudden car doesn't go over 300hp and feels choked saw a-lot of people were having the same problem just took my car to dealer let my advisor know what was going on and there is no codes what so ever on dash having him replace my mufflers to see if that will hopefully solve the problem will keep you guys posted
