Torque specs for lug nuts
Old 04-17-2019, 01:32 PM
Nex1's Avatar
Just wondering if anyone knows that the torque specs for the wheel lug nuts are? Gonna change out the winter tires soon
thanks!
Old 04-17-2019, 01:39 PM
diamondblak05's Avatar
Too many to list
I thought it was 100 ft. lbs but I could be wrong.
Old 04-17-2019, 02:21 PM
bobblehead's Avatar
go fast grocery getter wagon
owners manual - under "wheels & tires" says 110 lb-ft or 150 Nm.
You can confirm it yourself.
Mandarin (04-17-2019)
Old 04-17-2019, 02:26 PM
Nex1's Avatar
Thanks!
Old 04-19-2019, 10:21 AM
suby01's Avatar
2024 AMG GLE 53
Does anyone have any recommendations for a torque wrench? Thats preferable for MB, or just a simple autozone off the shelf?
Old 04-19-2019, 11:01 AM
wassup61's Avatar
E63S4S
Buy a beam style wrench... nothing to go out of calibration, and will fit the bill for everything you need.
https://www.sears.com/craftsman-1-2-...4aAue3EALw_wcB
Mandarin's Avatar
e63s
$300 torque wrench and $19 harbor freight torque wrench for nuts will do absolutely the same stuff this is not an engine assembling ))))
Old 04-19-2019, 11:28 AM
Too many to list
I have been using one of those $19 harbor freight torque wrench for years without fail...only on lugs though. Don't see any reasons to spend anymore than that.
Old 04-19-2019, 11:38 AM
Mandarin's Avatar
e63s
I also have TW from HF got it for $9 with a coupon, and it's perfect for seasonal wheels change.
Old 04-19-2019, 01:36 PM
E634Me's Avatar
2018 E63S AMG
You could always just use a 2 ft long bar and hang a 50 lb weight at the end of it. That would place a torque of pretty darn close to 100 lb-ft on the lug nuts.
The 100 lb-ft torque using this method would of course only be nearly accurate when the bar is horizontal. The torque would be 0 when bar is vertical.
I say pretty darn close and nearly, in the above text because you have to integrate the weight of the bar along the distance to get the additive effect of the bar to the 50 lb weight, but the major contribution will be from the 50 lb weight unless you use a really heavy bar.
I have several different torque wrenches of various grades and after a while your hand gets fairly well calibrated and you can almost set them exactly without the torque wrench. But, typically I install the nuts to about 10 to 20 lb-ft under the target by hand then use the torque wrench to finish them off.
Old 04-20-2019, 01:20 PM
Nex1's Avatar
Does anyone have any suggestions for the jack adapters?
Old 04-20-2019, 03:33 PM
64stingray's Avatar
E63 S Sedan
Burger Motorsports Mercedes Benz Metal Floor Jack Pad Adapter by BMS - Fits 2000-Present Mercedes Benz Vehicles
by Burger Motorsports
Amazon Amazon
Old 04-26-2019, 10:42 AM
otakki's Avatar
FF. W212 E63 M156 non-pano 18" P2 ParkT NightV (gone but will be missed).
Right on! Yup, nothing to go out of calibration. That's the wrench I have!
Quick Reply: Torque specs for lug nuts
