Resetting TPMS from factory setting
I'm trying to figure out how to lower the TPMS setting as I've lowered my tire pressure from factory setting and the low pressure warning is activated at basically 46 PSI or lower. Thanks in advance.
go fast grocery getter wagon
mine is set for 36 psi (square) for my summer set and 35 psi (square) for winter set and I have never gotten a tpms warning at all.
Have you tried by just resetting the tpms thru the service menu ? I believe once you have done that, then the system will take on the new tire pressure setting as the new default value
bobblehead (06-14-2019)
