different rpms in C vs S modes
Old Jun 20, 2023 | 08:01 AM
odessit's Avatar
2009 E350 Sport (gone) 2012 E350 (gone ) 2014 E63s ( gone ) 2016 E63S Diamond white 2019 E63s AMG
I have a question, when the car is in C mode and switches to S should RPMS rev higher? when is S+ and Race mode engine revs higher ( can be seen and felt )
Thank you!
Old Jun 20, 2023 | 08:12 AM
kponti's Avatar
E63
Thank you!
Yes it does, but not nearly as high as in S+ or Race.
However if you have been driving about lazily, you won't notice much of a difference in shift rpm between sport and comfort
Old Jun 20, 2023 | 08:37 AM
W205C43PFL's Avatar
That is true, the transmission is constantly learning driving habits.
Old Jun 20, 2023 | 07:05 PM
JTS97Z28's Avatar
2014 AMG E63S
If I’m sitting in park, and switch from comfort to sport+, my idle rpm increases. So yes that is normal.
Old Jun 21, 2023 | 08:57 PM
W205C43PFL's Avatar
Does the transmission learn per key? For example if you drive with the main key does it adapt a set of driving habits but if you drive with the spare key it then adapts again thinking it is a different driver?
Old Jun 21, 2023 | 09:36 PM
superswiss's Avatar
2019 C63CS
Are you talking about the idle rpm? If so, no. 99% sure, but I don't use Sport very much. In Sport+ and RACE, the idle rpm is several 100 rpm higher. If you are talking about while driving, then yes, Sport holds the gears slightly longer than Comfort, so your average rpm will be higher. Sport+ holds lower gears even longer and so does RACE mode. But as said above, if you drive casually then even Sport+ starts shifting to higher gears.
Old Jun 23, 2023 | 09:01 PM
W205C43PFL's Avatar
Sorry may I ask who your post was addressed to? Would it be OP?
Old Jun 23, 2023 | 09:02 PM
superswiss's Avatar
2019 C63CS
Yes, OP
Old Jun 23, 2023 | 09:18 PM
W205C43PFL's Avatar
Yes, OP
I see. Thanks for clarifying.
