Knocking
Lets just run through a quick safety checklist to make sure we do our best to avoid hurting anything:
Codes?
Smell the oil on the cap, fuel?
Check your oil level. What kind of oil? No additives?
Check the condition of your plugs if you can, sometimes a particularly bad misfire can make this plopping sound. cars approaching when the plugs should be out
hows your gas? Fresh tank? No additives?
Coolant level?
Does this go away when it warms up?
M177's use a dual mass flywheel that make this plopping noise, it doesn't sound metallic as least from that recording. It can be normal. Sometimes on the M177 this noise is actually normal.
I can rule out the particularly bad stuff, cylinder scoring, rod bearings, broken piston, chain guide. I'd just need to make sure the timing tensioner is working and you don't have chain slap. Consider used oil analysis.
www.amsoil.com/p/oil-analyzers-test-kit-postage-pre-paid-oaippkit/?zo=7236674
Alpha European Autotech
Purchase Amsoil at 25% off from me
Chris Tran, Retired Alpha European Autotech Owner
Amsoil Independent Dealer #7236674
Codes?
Coolant level?
thanks for the detailed response,
i just got the car yesterday with 54k miles, I’m not sure if it has mods but I don’t think it does, I’ve driven the car 50 miles since I got it the performance seems fine I did do a 0-60 with race start and it measured 4 second to 60 on the track pace which is a little off than what it’s supposed to do but other than that the performance doesn’t seem off.
the oil should of just been changed because I just bought it and they said they’ll change it
i did. scan for code there was two stored codes p002177 and p002477 I cleared them and they didn’t come back, there weren’t any other code.
i couldn’t smell fuel on the oil cap.
the oil level is right before the max and they said they put 5w-40 .
im not sure about the plugs, might be a misfire because I did notice some vibration but there’s no cel.
I think the gas is a little old because the car has been sitting at the dealer for a good amount of time
the coolant level is between Max and min
when it’s cold there’s no knock when it warms up it starts knocking on the left side of the engine where the ecu is
Is it a misfire or knock? Oil smoke from tailpipe? Excess unburned fuel smell from tailpipe?
yeah those cars are rated at 3 seconds 0-60 i don't really joyride my customer cars so I couldn't tell you. I think it's the flywheel, but I'll wait for wiser people to show up
It’s a knock but could be a misfire causing the knock I’m not sure
there isn’t any smoke coming from the exhaust
I don’t smell any fuel from the tailpipe
this is what the car sounds like at idle in comfort with the valves open
Tailpipe diagnosis might be telling you something is rattling/loose/cracked in the exhaust. Inconclusive evidence.
they don't always hard-code when something is wrong (CEL)
Do not hesitate for any reason. It may cost you zero. If you wait, cost could be very very high. Do not put any miles on the car except ppi and going back to seller.
Vibration at or near idle points to either misfire or engine mounts that are starting to fail.
Misfire on early build 4.0TT is common. Failing engine mounts is common across MB models.
good luck with your dealer appointment although if you're out of warranty I would prefer if you went to a local specialist shop
I took the car to the dealer 3 weeks ago it took them 3 weeks to replace a fuel injector and were saying the knock is normal I told them multiple times that I had the same car before and the knocking isn’t normal but they didn’t listen so I just took the car home and I was just bored and I went took out the spark plugs, I take out the spark plug on the side where the sound is coming from and the spark plug is loose it’s hand tightened, I take it out the whole plug is black covered in carbon. I cleaned it up and put it back and everything is solved no more knocking and the car isn’t down on power
moral of the story is don’t believe what the dealer says they don’t know anything about these cars
on the video you can clearly hear that popping sound from the passenger side. It was not making much sense since valve clearance would not sound like that and definitely not rod knock. A lose plug would let some combustion out through there. Intresting enough, both videos you can hear the sound at the same time with it sounding less in sync at the rear of the car...
another one for the TSRM for this car for the DIY crowd!
