View Poll Results: Does your 2020+ E63S have an RMS leak?
None
75.00%
A little manageable leak
5.00%
Repaired full on leak
20.00%
Repaired and leaking again
0
0%
Voters: 20. You may not vote on this poll
Is RMS leak potential (inevitably?) a deal breaker
Old Jan 6, 2024 | 01:23 AM
CameronCali's Avatar
AMG
I’m coming from a C63S coupe and am looking to get a 20k mile E63S for a dad mobile.
I’m reading a lot about the horrors of fixing the RMS leak… I wouldn’t even want a small one and leak in friends/families garages/street.
Is the RMS leak really that common?
Thanks everyone
Old Jan 6, 2024 | 05:23 AM
bobblehead's Avatar
go fast grocery getter wagon
Do remember this forum only contained a tiny fractions of worldwide registered e63 owners of 2020, 2021 and 2023 is being way too new to have any issue. The engineering has not changed since the introduction of the w213.
Old Jan 6, 2024 | 06:47 AM
HBerman's Avatar
2024 AMG EQE SUV , 2021 E63S Wagon - gone, 2018 E63S Sedan - gone
Thanks everyone
My former 2021 wagon had no oil leaks at 20,451 miles.
Old Jan 6, 2024 | 08:45 AM
DrSkywalker's Avatar
2020 E63s AMG Wagon, 2014 SL63 AMG, 2019 Audi Q8
Our 2020 E63s wagon with 45k+ hasn't shed a drop.
Old Jan 6, 2024 | 10:26 AM
Captain Cosik's Avatar
None
2018 wagon at 46K miles (second owner) not a single issue.
Old Jan 6, 2024 | 10:36 AM
chassis's Avatar
2017 GLE350 4MATIC
The mileages in the responses are low. Inconclusive to say, based on low mileage, how likely the oil vapor separator failure is or will be.
Oil vapor separator failure leads to RMS failure. There have been reports on this site of M177 RMS failure not caused by oil vapor separator failure, but these reports are fewer than RMS failures caused by collateral damage from failed oil vapor separators.
The question to ask yourself is, how long will you own the vehicle? For short duration and low mileage ownership, in accordance with the responses so far, you could escape unscathed. Hopefully. Maybe.
If you are seeking a longer term relationship (4 years or approaching 100k miles), either plan financially for an RMS replacement job, buy an expensive warranty or skip this car.
Expensive warranties are not guaranteed to solve the financial problem and they do not solve the time/inconvenience problem.
Old Jan 6, 2024 | 11:57 AM
nyc_amg's Avatar
2018 E63S AMG
59000 miles 2018 E63S no RMS issue.
Old Jan 6, 2024 | 05:17 PM
whoover's Avatar
'19 E63S sedan
The part numbers for the recently replaced oil separators on my E63S are updates to the original part numbers. I'm hoping that the problem has been fixed for cars with the new parts, but time will tell.
Old Jan 7, 2024 | 07:46 AM
SilverE5588's Avatar
'15 E63S,'21 LCI M5
Mind adding the new part #'s here if you don't mind ?
Old Jan 7, 2024 | 08:41 AM
bobblehead's Avatar
These seems to be the latest … late 2023
177-078-54-00 OIL SEPARATOR
177-078-55-00 OIL SEPARATOR
012-990-50-04 CAPSCREW W HEXAL
DRIVE
177-010-37-08 CRANKCASE COVER
13 000000-001144 HEXALOBULAR BOLT
1 Q-1-03-0005 G 40 ANTIFREEZE
2 002-989-06-03-12 TRANSMISSION FLUID
1 177-201-09-00 ELASTOMER MOLDED SEAL
mine was replaced with the same parts in Dec 2022, except crankcase cover was not replaced at the time
Old Jan 7, 2024 | 10:10 AM
HBerman's Avatar
The part numbers for repair are not going to correspond to the engine in the vehicle, but rather to the replacements. The engine is built on a totally separate assembly (one builder), but the part numbers are not carried over to the final assembly. I don't know how much time elapses from AMG engine completion to final assembly. Regardless, from all of the reports herein, it appears to be a crap shoot as to if/when there will be an RMS failure. One poster found a vehicle which had the repairs completed and which had another failure within 600 miles.
Old Jan 7, 2024 | 01:28 PM
whoover's Avatar
'19 E63S sedan
I'm not sure what you mean, but the new oil separator 177-078-54-00 replaces 177-078-14-19 and 177-078-30-00. 177-078-55-00 replaces 177-078-15-19 and 177-078-31-00.
Old Jan 7, 2024 | 09:55 PM
HBerman's Avatar
What I mean is that you can't tell the part numbers of the final assembly on the car. You only know what are the new replacement part numbers.
Old Jan 15, 2024 | 12:35 PM
figuwx's Avatar
2018 AMG E63s Ed1
Honestly i think it is like all forums, we are but a subset of owners.
If it helps any
2018 E63s
134,457 (two weeks ago)
No RMS issues. Even in -13F ambient temps.
Old Jan 15, 2024 | 01:11 PM
zukmeister's Avatar
2023 E63S AMG - Grey Magno
If it helps any
2018 E63s
Impressive mileage? Original owner? If not, how do you know RMS wasn't replaced before?
I'm hoping the RMS is overexaggerated on these forums because this is my first MB and it worries me a bit
Old Jan 15, 2024 | 01:50 PM
sixfive's Avatar
'19 E63S
70k here and just had mine done
Old Jan 15, 2024 | 01:56 PM
zukmeister's Avatar
Hello fellow Idahoan. Still want to meet up when the weather gets a bit nicer in spring. Mine is sitting under the cover currently
Are you driving it with all this snow on the ground? How does it do?
Old Jan 15, 2024 | 02:17 PM
sixfive's Avatar
'19 E63S
hi there
Absolutely would love to do that! I sure am except today I couldn't because after the snow plow cleaned the road in my neighborhood, they put a huge pile of snow into my driveway and I haven't had a chance to remove it yet so I had to take wife's GLE. But I'm planning on cleaning that today and use her again. Otherwise I have not had any problems what so ever! Just have to watch for all the other idiots thinking the hugely extended stopping distance on ice doesn't apply to them in their big 4x4 trucks . . .
Old Jan 16, 2024 | 10:51 AM
Sunbeltgolfer11's Avatar
E63s SL550 GL450
I do recall one owner reporting the RMS failure at 18,000 miles. I don't remember what year the car was. If you plan to own one of these cars I think you should resign yourself to the fact that there is likely going to be an issue with RMS at some point.
Old Feb 13, 2024 | 04:45 PM
'15 E63S,'21 LCI M5
Looking at a 213 in the 65-70k mi range . Had a ppi done & no rms leak detected . Separators are original , I guess I can send it & forget it . Or pre-emptively do them my self. Have the wis for the separators , while it's not a walk in the park it is doable. Any opinions, looks like most are leaving them alone.
Old Feb 13, 2024 | 09:42 PM
chassis's Avatar
2017 GLE350 4MATIC
Change the separators. What is the argument to the contrary?
Old Feb 14, 2024 | 01:02 AM
'15 E63S,'21 LCI M5
Yeah the contrary isn't good ha. If I pick it up - I will get the separators/related parts & make a diy. Has anyone I missed here done them diy yet
Old Feb 14, 2024 | 11:15 PM
graphitegreyamg's Avatar
2023 E63S Wagon
Not an easy job. I saw the car at the shop with just the small part of the separators exposed for R&D work to install a catch can and saw the separators dissected first hand. To get to the one inch exposed corner of the separator needed the left-side engine harnesses moved out of the way. It’s a tight fit as it is. Coolers, I would think also, need to be removed.
