Ultimate Guide to the w213 AMG E63 - Issues/Fixes/DIY
Old 07-29-2024, 01:53 PM
PeterUbers's Avatar
Received 2,162 Likes on 1,520 Posts
2014 E63S; AMS 100 octane ecu tune; edok tcu tune; BB intakes; dyno tuned
FIX FOR DASH POP/CREAK - tighten torx bolt for aluminum brace in engine bag by drivers firewall.
https://mbworld.org/forums/w213-amg/...e-decline.html
SerottaD's Avatar
1993 300SL, 2007 RAM 2500 5.9L Cummins G56 6-speed, 2009 CLK350, 2018 AMG SLC43, 2018 AMG E63s wagon
What's the VIN?
Old 07-29-2024, 01:55 PM
ichap's Avatar
2016 Porsche Cayenne GTS
WDDZH8KBXKA559152
I ran the carfax, shows dealer service history but often just says "recommended maintenance performed", without specifics.
Old 07-29-2024, 02:28 PM
SerottaD's Avatar
If you have a relationship with a MB dealer (or realize you're going to need one), go to your friendly service rep and ask if they would run a VMI report for you. Tell them (truthfully) that you're looking to buy this car and would be bringing it to them for service. So could they help you look up the background on the car?
Of course, if the car was never serviced at a MB dealership, there will be no info, but that is probably a clue to run away unless it's an impeccable example from a known specialty house.
Old 07-30-2024, 12:41 AM
Caro's Avatar
E63s
Originally Posted by I.T. Guy
I'll add another "common" issue is once in a while power will drop drastically from the Exhaust Flaps sticking closed needing replacement/repair.
That's about it that I can think of "major" issues on this platform.
I got the renntech mufflers on my E63, do you know if the problem is with the motor/module or with the physical flaps?
Old 07-30-2024, 12:44 AM
PeterUbers's Avatar
Exhaust Flaps - boost loss
https://mbworld.org/forums/w213-amg/...ost-power.html
Old 07-30-2024, 05:51 PM
  #32
PeterUbers's Avatar
Exhaust Flap - loss of power (more info)
https://mbworld.org/forums/w213-amg/...flat-spot.html
Old 08-06-2024, 11:13 PM
  #33
PeterUbers's Avatar
TRANS OVERHEATING, COOLANT LOSS - with solution
https://mbworld.org/forums/w213-amg/...coolant-2.html
Old 08-08-2024, 04:13 PM
  #34
OBP
OBP's Avatar
Lexus SC430, CLS550 4matic, GLK350 4matic, Volvo XC90 T8, E63 S AMG
OP ( i.e. @ichap ), you still looking for someone to do a PPI on an E63S in the Miami area ? Have a recomm for you - PM me if you would like - this guy did a good job for me on my 2021 E63 purchase in April last year
Old 08-12-2024, 06:57 PM
  #35
PeterUbers's Avatar
BEST EXHAUST SET UP
https://mbworld.org/forums/w213-amg/...s-exhaust.html
Old 08-16-2024, 12:25 PM
  #36
PeterUbers's Avatar
WHATS THIS TANK IN THE TRUNK OF MY E63
https://mbworld.org/forums/w213-amg/...omponents.html
Old 08-17-2024, 06:27 PM
  #37
Super Moderator
Wolfman's Avatar
Received 3,340 Likes on 2,064 Posts
Now a sticky!
The following 2 users liked this post by Wolfman:
I.T. Guy (08-17-2024), PeterUbers (08-17-2024)
Old 08-17-2024, 07:33 PM
  #38
PeterUbers's Avatar
MICHELIN PS 5S DISCUSSION
https://mbworld.org/forums/w213-amg/...ts-ps-5-s.html
Old 08-17-2024, 07:48 PM
  #39
PeterUbers's Avatar
ANOTHER RMS DISCUSSION WITH UPDATED PART NUMBERS FOR REPAIR
https://mbworld.org/forums/w213-amg/...-2018-e63.html
Old 08-21-2024, 03:20 PM
  #40
PeterUbers's Avatar
AIR BALANCE FRAGRANCE FIX
https://mbworld.org/forums/w213-amg/...nce-fixed.html
Old 08-21-2024, 08:45 PM
  #41
PeterUbers's Avatar
P1525 EVAP System High Pressure Line Check Valve Stuck Open - bad PURGE VALVES
https://mbworld.org/forums/w213-amg/897470-o-p1525.html
Old 08-23-2024, 11:48 AM
  #42
PeterUbers's Avatar
GREAT ARTICLE ABOUT RMS LEAK, OIL SEPARATORS AND POTENTIAL SOLUTION
https://www.63motorsports.com/amg-bl...er-m177-update
Old 08-26-2024, 05:27 PM
  #43
PeterUbers's Avatar
W213 SERVICE INTERVALS/MAINTENANCE SHEET
https://mbworld.org/forums/w213-amg/...-u-1208dn.html
Old 08-27-2024, 06:55 PM
  #44
PeterUbers's Avatar
EXTENDED WARRANTY DISCUSSION AND RMS LEAK COVERAGE
https://mbworld.org/forums/w213-amg/...y-pricing.html
The following 2 users liked this post by PeterUbers:
Highline-Autos.com (08-27-2024), vich3 (08-28-2024)
Old 08-30-2024, 12:53 PM
  #45
PeterUbers's Avatar
AGGRESSIVE INNER TIRE WEAR
https://mbworld.org/forums/w213-amg/...-tire-psa.html
Old 09-01-2024, 12:25 PM
  #46
PeterUbers's Avatar
P0128, CEL, LOSS OF POWER - Tstat replaced
https://mbworld.org/forums/w213-amg/...ss-torque.html
Old 09-02-2024, 10:19 PM
  #47
PeterUbers's Avatar
BUYING A 2018 E63 WITH LEMON TITLE
https://mbworld.org/forums/w213-amg/...e63-wagon.html
https://mbworld.org/forums/w213-amg/...mons-sale.html
https://mbworld.org/forums/w213-amg/...ns-abound.html
https://mbworld.org/forums/w213-amg/...n-18-e63s.html
Old 09-05-2024, 08:53 AM
  #48
PeterUbers's Avatar
DRIVING IN S+ IS NOT SMOOTH
https://mbworld.org/forums/w213-amg/...cle-jerky.html
CaliBenzDriver (09-25-2024)
Old 09-05-2024, 02:57 PM
  #49
PeterUbers's Avatar
ANOTHER NOT SMOOTH TRANS DISCUSSION
https://mbworld.org/forums/w213-amg/...ngagement.html
AND ANOTHER (MCT IS NOT AS SMOOTH AS TORQUE CONVERTER)
https://mbworld.org/forums/w213-amg/...on-issues.html
Old 09-07-2024, 08:15 AM
  #50
PeterUbers's Avatar
ANY RMS LEAKS ON 2021+ MODELS?
https://mbworld.org/forums/w213-amg/...lift-e63s.html
Quick Reply: Ultimate Guide to the w213 AMG E63 - Issues/Fixes/DIY
