rattles from the rear deck, common issue and solution
Old Mar 18, 2025 | 12:56 PM
natesamg's Avatar
2020 E53 AMG Sedan
new to me 2020 E53 sedan. the rear deck behind the rear seats rattles quite a bit. i poked around back there and couldn't find what may be causing it. was wondering if this was a common thing that others have solved previously before trying to pull the deck apart to find the source
thanks!
Old Mar 18, 2025 | 01:33 PM
bobblehead's Avatar
go fast grocery getter wagon
did you have anyone sitting at the back and see if that can be located ? Have couple of people if possible. Could be anything from loose bolts or just needing some sort of felt tapes to cushion the noise.
Old Mar 18, 2025 | 01:53 PM
PeterUbers's Avatar
Don't forget to consider noise coming from the pillars -- or in the trunk that is referring a noise to the cabin
Old Mar 19, 2025 | 01:04 PM
natesamg's Avatar
2020 E53 AMG Sedan
will take a look and report back. over bumps it sounds like the rear deck rattles against something may just need to add some rubber spacers or insulation
