MBWorld.org Forums
MBWorld.org Forums (https://mbworld.org/forums/)
-   W213 AMG (https://mbworld.org/forums/w213-amg-214/)
-   -   I'm an idiot (https://mbworld.org/forums/w213-amg/912846-im-idiot.html)
LumpyCam May 11, 2025 04:47 AM
I'm an idiot
Have done something stupid today to my new car.
I have a 2017 E43 Japanese wagon import here in Australia.
Because the Japan FM radio stations do not cover the whole spectrum here, a mate and i was looking around in the settings with my Launch scanner to see if it was a simple change.
Found a setting under -
system select
information communication
audio / command
variant coding
tuner app
031 range type am/fm
was set to japan
there we found a drop down list with various countries names listed, ie; europe / japan / australia / korea etc
so we picked "australia"
we made a backup of existing settings then pressed write....
well the dash went to japanese writing between the gauges, the infotainment writing and the spoken "insert ETC card" is in japanese....
so we went back in and hit restore, made no difference.
went back in and changed back to Japan, made no difference.
How screwed am I?
CaliBenzDriver May 11, 2025 05:33 AM
Don't call yourself an idiot for experimenting a nearly good idea.
This may be a limitation of the scanner or the car itself.
Plug car on a Xentry system to gain perfect compatibility....
chassis May 11, 2025 07:09 AM
Calling @BenzNinja
W205C43PFL May 11, 2025 11:07 AM
system select
audio / command
variant coding
tuner app
was set to japan
How screwed am I?
What's an ETC card?
Cosworth2000 May 11, 2025 11:39 AM
You can try to unplug the battery and wait until all the modules go to sleep and see if the radio will restart.
C Swenson May 11, 2025 04:07 PM
Originally Posted by chassis (Post 9158706)
Calling @BenzNinja
I agree. Contact @BenzNinja to get expert help. I've used him for the last three years.
Extremely knowledgeable, patient, and tenacious when confronting any problem. :y
LumpyCam May 11, 2025 05:33 PM
Unfortunately joining Benzninja Is a bit cost prohibited at the moment. The exchange rate is the killer. The 750$ joining fee is close to 1200$Au at the moment. Then there's the cost of all the other equipment needed.
W205C43PFL May 11, 2025 05:50 PM
Did you tell him you are a forum member here and get a discount?
LumpyCam May 11, 2025 06:06 PM
Originally Posted by W205C43PFL (Post 9158811)
What's an ETC card?
It's the Japanese electronic toll road payment tag system. There's a small box in the glovebox that takes a sim card of some sort and a transmitter on top of the dash above the defroster air ventilation. Without a card inserted it gives a visual and spoken warning when engine is started.
Damn annoying. Was going to be next off the list to find and deactivate....
W205C43PFL May 11, 2025 07:00 PM
I guess you can't just unplug it or remove the fuse to it?
C Swenson May 11, 2025 11:29 PM
The cost for a lifetime membership is $499, not $750.
And yes, you are right, equipment will cost another $600 or so.
LumpyCam May 12, 2025 04:29 AM
Sorry, I thought i read it as 750$ joining fee somewhere a few weeks ago when I was researching the car.
499$US is about 780$AU at today's rate, makes it a bit easier to swallow.
Will investigate some more over the next few days.
Apart from fixing my radio and text stuff up and then setting to Australian frequency's , I was thinking -
- changing the blinker count,
- remove reverse gong,
- change the nav / maps to Australia
- transmission last mode remember
- update any module software
What are some good / recommended mods to look at?
Is there a coding price list available?
trigital May 12, 2025 07:47 AM
All that you can find it here on forum completely free, you only need to use search function, to buy a 20USD Openport interface and to use a Windows laptop with all security enabled. This way you will learn too and you can contribute here as well.
W205C43PFL May 12, 2025 08:02 AM
That is not too bad, especially given the support and ease of access you have.
W205C43PFL May 12, 2025 08:04 AM
not to discourage people to use the search function but honestly speaking, the search function on this forum is terrible, I recommend putting quotation marks of the keyword you want to search on google then typing site:mbworld.org instead.
W205C43PFL May 12, 2025 08:05 AM
I notice your signature says software version 49.52? Is that the COMAND version?
trigital May 12, 2025 08:25 AM
That's very bad because all his expensive solutions is leached from here.
streborx May 12, 2025 08:44 AM
When the vehicle was imported from Japan, was it subjected to a homologation by the importer? I'm assuming when in Japan it was configured as it now exists with Japanese enunciations. Seems strange that it's now stuck there and can't be converted back to Aussie. Any chance its import itinerary can be traced back to see if someone along the way can assist?
W205C43PFL May 12, 2025 08:59 AM
no comment : ) :)
PeterUbers May 12, 2025 09:01 AM
The cheapest solution:
learn Japanese.
W205C43PFL May 12, 2025 09:15 AM
learn Japanese.
might not be a bad idea, I like the language actually : )
TugboatBill May 12, 2025 10:23 AM
learn Japanese.
Or do what cosworth2000 suggested, disconnect the battery, wait a while, and hook it back up. It can't hurt and, as it is just one big computer network, it just might come back up properly.
S_W222 May 12, 2025 10:34 AM
Fully agree..... Hopefully OP can find answers he is looking for.
Also, if you want to save time and money, just get a one-time service from @EleBest (from his signature: Elebest - MB Original upgrade and retrofit, Coding and Programmer: Whatsapp direct link: +6597335000 ). He is a forum sponsor vendor here, and go-to person for so many people around. I believe he is the only one besides RJ who also can code new MBUX cars too. I've used him several times fo a single item service (no subscription fees or things like that, no equipment renting or items that need to be shipped with waiting time, all fully remote if you have a cable and your own PC).
W205C43PFL May 12, 2025 03:19 PM
Worth trying but there is also an aux battery right?
W205C43PFL May 12, 2025 03:20 PM
He is especially good at programming ILS : )
© 2026 MH Sub I, LLC dba Internet Brands
