Snow Tires for an MY05 E320 CDI
Old 10-24-2006, 10:27 AM
DavidNJ's Avatar
'05 E320 CDI;'04 S2k;'94 Supra TT;'10 QX56;'38 Buick;98 Port City Offset Late Model
16" wheels. It seems there are some new tires from Dunlop and maybe others.
Which is the best H/V or equivalent snow tire available? We had PA2s for the past two winters.
Thanks,
David
Old 10-24-2006, 12:48 PM
TR Moderator & Tire God
Luke@tirerack's Avatar
depends on the weather
The Blizzak LM25 would be my choice ....
use this link to find out more info or to place your order
Old 10-25-2006, 12:21 AM
DavidNJ's Avatar
Two years ago you recommended the than new Michelin PA2s over the then new Bridgestone LM25 and Dunlop M3. Their are no comparative tests on the Tire Rack site. Owner reviews seem to place both the Dunlop and Michelin above the Bridgestone, especially in dry handling and noise.
The only new tire here is the Dunlop 3D. Although they are still selling the M3, Tire Rack seems to be only selling the 3D.
Since the Dunlop M3 seems to have the best owner reviews, is the 3D an even better tire? It is also $78 or so dollars cheaper for a set.
David
Old 10-25-2006, 08:57 AM
while the Michelin and the Dunlop do offer better dry road handling the LM25 is better in the snow .... the new 3D is the replacement for the M3 and the only change is a slight tread design change to increase snow traction. The internal carcass and rubber compound has not changed
best performance ranking IMHO
snow traction = Blizzak
Ride quality = Michelin
overall balance = Dunlop
with the limited info given on many internet posts I will always err on the side of snow traction when discussing winter tires
Old 10-27-2006, 06:14 AM
DavidNJ's Avatar
With an emphasis on low noise and dry/wet traction, which tire do you prefer?
The Michelins may have one advantage for us...if we have a problem, we can use one of the old tires (1/2 worn) as a spare. Although it could probably be used with the others also.
David
P.S.
We bought the Firestone Firehawk Wide Ovals last spring...and they are incredibly good: performance, ride, handling. Possibly the best tire available for this car.
Old 11-26-2007, 12:08 AM
GermanCarShow's Avatar
2017 C43, 1980 450SL, 1966 230SL, 2006 Jeep Rubicon
I'm going to an old topic for an update.
I hope I'm not: :
I was wondering how the Dunlop 3D tire is being rated or reviewed, now that it's been around longer. I still don't see any analytical comparison tests for it.
Thanks,
Old 11-28-2007, 02:49 PM
grane's Avatar
G350 Bluetec
Hankook Icebear 300
David
P.S.
I would try these tires if they are available in your size. See my other threads. I use them on my CL55 and they are cheaper and perform at least as well as the expensive alternatives. They are VERY popular in Europe.
Thanks,
Grane
Old 11-28-2007, 07:27 PM
Thanks,
Grane
Grane,
OK, I give up. Are you referring to Michelins (snow tires) or the Firehawk Wide Oval (performance tire)??
Old 11-29-2007, 06:38 PM
Tank7's Avatar
2017 GLC 300 Coupe'
Had Blizzaks on my Bimmer and now on my EClass. Very low noise, does well in dry weather and will work great in the snow. Better than Alpin's (have had both).
Old 12-04-2007, 03:16 AM
beverlykasper's Avatar
c220
Old 12-04-2007, 09:56 AM
cyclrder's Avatar
18 E63s Wagon 15 GL63 (sold), 10 Turbo TT MT, A36 Bonanza, 20 JLU Rubicon
I just put my new Dunlop D3s on my 17in wheels and switched off the AMG 18s
just as far as dry handling... the D3s do pretty well for a dedicated snow tire... not nearly as noisy as my PS2s .. and certainly a more compliant ride.
we had an inch of snow and the tires were great too .... so far happy.
just my two cents...
Old 12-04-2007, 12:32 PM
grane's Avatar
G350 Bluetec
I'm referring to the Snow Tires
Originally Posted by GermanCarShow
Grane,
Icebears rule in snow and ice!
Old 12-06-2007, 12:18 AM
We got 5 inches of snow last night/today. I got the Dunlop Wintersport 3D tires on the C230 just in time!!! I like them so far, considering the sidewall profile and width of the tires (stock size).
Quick Reply: Snow Tires for an MY05 E320 CDI
