Rotors OEM vs. Brembo
In reading some threads there seems to be somewhat of a consensus that the OEM rotors tend to warp. My 2014 C300 has 27K on the odometer and when braking there is a grabbing/releasing feeling and an audible sound. My mechanic says most likely warped rotors on the front, which I tend to agree with.
So . . . trying to decide between OEM or Brembo or possibly Meyle. Anybody have any experiences, preferences with these.
if your rotors don't look glowing red like this:
It might be worn, but is certainly not warped.
Brake systems need routine maintenance, ignoring this will result in brake failure, noises, pedal feel change, etc. The grabbing feeling might need to check out the caliper pins. A simple lubricating of parts will reduce noise and changing the brake fluid will improve brake feel.
You can't really go wrong with brake rotors, they all eventually need to be replaced. They get worn by the pads and weather anyways. I have used Brembo cast iron and Centric cast iron rotors and paired them with Akebono ceramic pads and never had an issue.
