2017 GLE43 wheel swap now causing major handling issues
Old 06-12-2018, 11:54 AM
JDYER's Avatar
gle43
2017 GLE wheels where swapped to an OEM set of AMG wheels and tires (takes off's from a GLE63
Original Wheels where 21" stock tire
New Wheels 22" stock tire
The issue is now the car seems to be all over the road, I feel like you removed all rebound damping from suspension.
Any direction or advice would be great
Jeff
Old 06-12-2018, 07:30 PM
JohnnyC's Avatar
2013 GLK350
the only 22" for that chassis right now is this: (10J x 22 ET56 and 11J x 22 ET40)
This only fits the coupe.
There are many different 21" wheels have a few different offsets and a different tire pressure. So looks like you need to do some calculations or run a spacer.
Old 06-17-2018, 09:54 PM
Renntech6509's Avatar
2014 ML350
Do you have any idea if the regular coupe wheels will fit a 2014 ML350? They're 21x10 with 275/45 and the rear are 315/40 on 21x11.
Quick Reply: 2017 GLE43 wheel swap now causing major handling issues
