HELP suspension question
Old Dec 12, 2005 | 08:54 PM
artboon's Avatar
i have a 2001 e320. i would like to lower it with the eibach sport kit. i didn't put on my rims yet. my question is..after lowering, what needs to be done? do i just need to get the repair bolts from the dealer for the front, as well as rear adjustment kit and alighnment?... when i lower it, do i need to let it settle first before doing alignment and rear camber kit? any help would be greatly appreciated....
Old Dec 13, 2005 | 10:34 AM
Luke@tirerack's Avatar
TR Moderator & Tire God
depends on the weather
it is a common misconception that you need to let the suspension settle abit before an alignment ... I always do alignment directly after installation of lowering springs or any suspension component replacement
Old Oct 24, 2006 | 12:00 AM
gpizuorno's Avatar
What about of a rear adjustment after change the springs?. I know that tha car must be aligned after the front spring change, but what should be done in the rear?
Old Oct 24, 2006 | 12:03 AM
gpizuorno's Avatar
What about of a rear adjustment after change the springs?. I know that the car must be aligned after the front spring change, but what should be done in the rear?
