brake rotors question 97 c230
'97 C230
I'm searching on new brake rotors for my 97 c230.
I ran into different parts numbers(or different applications of different chasis?) for brembo rotors
F 647651-
-F 647650
A 545906-
-A 545905
what are those? where my car belong to?
thanks in advance
F 647651-
-F 647650
A 545906-
-A 545905
thanks in advance
My experience with changing-out to brembos on so many of my cars has been that the Brembo rotors are indexed to what they will go on. Last item in the index (after make, year, model) is engine. Any decent retailer should be easily able to identify which Brembos will fit on your car if you give them (enough of) the right information about your car. Lastly, you will often have a choice between plain face, slotted, and cross-drilled -- that might also result in different part numbers (for the different treatments). And of course front and rear rotors usually have a different part number .....
1967 Morris Cooper "S", 1983 911SC, 1997 Toyota Tacoma, 1999 HD FXSTB, 1998 C43
Those look like chassis numbers, if you ever have obtained the info sheet from the dealer, it would reveal those numbers for your specific vehicle. Also, I believe that if you call up those retailers, they'll be able to discern that for you as well. Check tirerack.com I believe Luke from that retailer can field your questions too, check on that respective topic on this forum - hope that helps!
It's an easy job by the way, I have a 1998 C43 and have recently performed the job if you need further assistance.
