Bolt fitment question
Old Jan 2, 2007 | 05:28 AM
chixdiggit's Avatar
W209 CLK
Hi,
I was looking into purchasing a set of the AMG 230 rims (20 spoke rims from SL55) for my 03 W209 CLK. When I asked for a quote from my local MB dealership for pricing reference and I was told that although the bolt patterns are the same for all MB vehicles, the diameter of the bolts on my car are slightly smaller than that of the SL, CLS, and S series. I was told that because of the different bolt diameters that the larger wheels will not sit 100% properly and could be a safety concern.
I've seen others out there with these rims. Is what the gentleman in the parts department telling me is true ?
Should I be concerned with the fitment issue if I plan to go ahead an go with these rims?
Thanks!
Nate
Old Jan 2, 2007 | 05:50 AM
CY's Avatar
CY
SL/M6
I think the offset on a SL or CLS is very unique and may sit too far past the fenders on a CLK...not 100% sure though.
Also, there are way better looking (and even possibly better performing) wheel options aftermarket, than those rims you are looking at....
Old Jan 2, 2007 | 02:27 PM
lkchris's Avatar
'10 CL550, '12 GL550
He's giving the the straight story and watching out for your safety.
Old Jan 3, 2007 | 04:41 AM
chixdiggit's Avatar
W209 CLK
Thanks for the info.
So if this is true then rims aren't interchangeable between all vehicles then.
In that case which vehicles have rims that are interchangeable with the w209 CLKs?
If I purchase aftermarket parts is there a different bolt size I need to be looking at other than the 5x112 bolt pattern specs and the offsets?
Is there a range of offsets (like a max and min) or is it plain and simple +35 only?
Thanks for you input guys.
