20's on a 2006 clk 350.
Old May 9, 2007 | 08:48 PM
mario1235's Avatar
Will 20's fit. I have a 2006 clk350. What is the proper fitment/size for this with no rubbing or having to roll/cut the fenders. I have a lease so I dont want to touch anything. Thanks!
Old May 9, 2007 | 11:38 PM
my06clk's Avatar
04 S430 (sold),05 X5 4.4i, 02 325i, 87 560SL, 85 Alfa Romeo
19" on this car is really tight. Especially since you do not want to mod anything. BUT, if you mind your offset a 245 30 20 will work fine.
If you go staggered you would have to use a 275 25 20. I'm not sure of you want to do that because you will have NOoo sidewall.
I would use a 37 or 38 ish offset especially in the front because if not you might be touching the shock and have to use a 5mm shim.
IMO. this won't look any better than a 19 unless you drop it. But since you want to stay stock on everything, I'd go with the easiest fitment. those tire sizes in a 20 are not the easiest to find either.
hope that helps..
Old May 10, 2007 | 04:36 PM
Luke@tirerack's Avatar
TR Moderator & Tire God
depends on the weather
there is not a 20" size that would be perfect .... I would not go with more than 19's .... the overall tire diameter needs to be 25.0" - 25.4" and while there is a 225/30-20 (which is 25.3") there is no 255/25-20 or 265/25-20 for the rear ... and the load capacity for the 225/30-20 is only 1135 lbs. and minimum for your car is 1356 lbs.
