9000 miles and need new Tires for S600
Old Oct 4, 2007 | 09:19 AM
asg's Avatar
asg
2007 S600
After 9000 miles all 4 tires on my 2007 S600 needed to be replaced. I have 21" Brabus wheels. The rear look like they wore out evenly, even though there seems to be alot of negative camber. The fronts were just worn out on the inside edge. They still had plenty of tread on the rest of the tire. I normally try and keep about 45 psi in all the tires. Just had the allignment checked and the only thing was that the front was toed out a bit. Everything else was within factory spec. Also the car was lowered with a Brabus module.
Any suggestions on getting a bit more life out of the front tires?
What psi should I be running? Getting different answers from everyone down here. Should I make any other changes to the alignment?
Old Oct 4, 2007 | 05:06 PM
Luke@tirerack's Avatar
TR Moderator & Tire God
depends on the weather
12k - 15k is common with performance tires so, 9k isn't that surprising .... there are some people who see even less because of their driving style
