Chronic Air loss problem...
Here's the story- never had a problem with the rim until I mounted a new tire. Tire was barely used and from a friend with no probs before. Now once I mounted tire kept going flat in the garage over a period of a week or so..
Had the tire remounted and seemed to go away for a while until now..regardless I'm buying new tires next week..
My question is bent wheel or bad tire?? I know I'll know once I mount a new tire but its bugging me till then..a trusted shop said this happens and they've seen it before- FYI tire size is 225/35/18..
FYI 225/35-18 is the wrong size for your car and it doesn't have the proper load capacity ... you should be running 225/40-18
Also- the tire is for my NSX, just posting here to try and gather more info...thanks for the input.
