AMG Wheels/Tire Presuure Monitor
Old Jan 14, 2003 | 06:08 PM
ignatz's Avatar
Question AMG Wheels/Tire Pressure Monitor
Does anyone know if the AMG 203 0r 215 series wheels will work with the tire pressure monitoring system on an '03 E500?
Old Jan 21, 2003 | 09:45 AM
Luke@tirerack's Avatar
TR Moderator & Tire God
depends on the weather
the wheels will work with the pressure sensor but, not on your car .... they do not have the correct offset and load capacity
Old Jan 21, 2003 | 02:56 PM
ignatz's Avatar
Thanks Luke
I should be more accurate in phrasing my questions. I understand that the CL (215) wheels will fit my car, but also understand that the silver w/ machined lip version is available only in 19", and that the only 18" version is the silver painted version that is actually gray. If you would indulge me in two more questions.
- Will the silver w/ machined lip version be available in 18"?
- Will the 19" accomodate the tire pressure monitor, which I understand is mounted inside the wheel?
Thanks for your help.
