Wider tire
Old Jan 30, 2003 | 09:24 AM
Kar don's Avatar
Mercedes-Benz
Wider tire
On my car it came with 215/45 ZR17. The tire I want only comes in 225/45 ZR17. Will this throw off suspension or speedometer or looks? The car has 17"x 7.0 rims.
Old Jan 30, 2003 | 10:06 PM
Mercedes Tuner's Avatar
99 C43 AMG & 2008 Corvette 1LT Z51 LS3
Tire Size Calculator: http://www.powerdog.com/tiresize.cgi
Old Jan 31, 2003 | 09:15 AM
Kar don's Avatar
Mercedes-Benz
it says 1.4% difference. Is that really bad?
Old Jan 31, 2003 | 09:43 AM
theine's Avatar
2014 GLK250 BlueTec & 2009 ML320 BlueTec
No big deal. My car came with 245/40-17 in the rear, now I have 255/40-17.
Old Jan 31, 2003 | 07:43 PM
I usually try to keep the tire size within a half a percent of stock tire size, unless I'm looking for different performance levels.
A difference of 1.4%: say you are traveling at 100Mph as indicated on your speedometer. You're actual speed would be 101.4Mph
Old Feb 4, 2003 | 08:52 AM
Kar don's Avatar
Mercedes-Benz
will the 225/45 ZR17 be ok on my 7 inch wide rim?
Old Feb 4, 2003 | 02:45 PM
theine's Avatar
Talking
Yes, no problem.
Old Feb 10, 2003 | 01:49 PM
AJChenMPH's Avatar
2008 Subaru Legacy GT Limited
It'll be okay, but if you're a really aggressive cornerer, then you may get a little more sidewall rollunder than if you had 17x7.5 or 17x8 rims. If you can find a tire that really stiff sidewalls, that may help counter that tendency...
EDIT: here's a pic of me at Lime Rock in 11/01. Tires are Nitto NT-450's in 225/45-17 mounted on 17x7.5 rims. You can see from the rear tire that even then there's a bit of deflection. It would only be worse if you use 17x7 rims. However, for everyday driving, you'd be fine.
Old Feb 10, 2003 | 02:02 PM
Kar don's Avatar
Mercedes-Benz
alright then that takes the pilot A/S out of my available choices.
