Porterfield or Greenstuff ??
Old Aug 13, 2003 | 03:10 PM
branshew's Avatar
C280
I'm trying to get rid of the annoying brake dust on my C280. I was thinking about changing the factory pads to an aftermarket brand to reduce the dust.
I don't want any loss of performance or any noise. Can anyone make any recommendations on the Porterfield or the Greenstuff pads? Do they squeak/squeal more than the OEM pads? Will the sensors fit into these pads? Will I need to replace the sensors with the pads?
Old Aug 17, 2003 | 02:10 PM
mleskovar's Avatar
'17 Jaguar XF
Porterfields
I use Porterfields in the front of my C320 and am very happy with them. Mine did not come with holes for the wear sensor, but I've read they have holes now. You only need to replace the sensor when they have worn through. I think the Porterfield pads perform as well or better than stock pads. No squeeling once broken in....and I used ceramic paste for lubrication. Make sure you follow a proper break in procedure.
Old Aug 17, 2003 | 04:16 PM
AJChenMPH's Avatar
2008 Subaru Legacy GT Limited
While I personally haven't tried either, my vote is leaning towards the Porterfields if money isn't an object -- the Greenstuffs are known to really eat rotors and actually dust more than they claim, while also being squeaky. I've never heard a bad thing about Porterfields. I'd run a set of R-4S's on the street myself if they weren't quite so expensive...(using Mintex Red Box right now on my car).
Old Sep 3, 2003 | 12:03 AM
aaaaa5star's Avatar
pads
I haved used ebc's not real impressed w/ them they do dust a lot. Stopping power is pretty good never tried porterfields. I tried a new pad called Rotex Gold on my car awesome stopping power they are really low dusting also. The rotex is a kevlar metallic pad dont know much more about it but it sure works good some of my friends that drive bimmers swear by this pad.
take it for what its worth,
mike
Old Sep 3, 2003 | 01:23 PM
Luke@tirerack's Avatar
TR Moderator & Tire God
depends on the weather
nobody going to mention Mintex ?????
I am staying out of this debate since we carry the EBC'c but, none of the others mentioned
Old Sep 5, 2003 | 03:55 PM
MARK CUMMINS's Avatar
209/W210 Estate /W211 modded by MBENZNL
Re: Porterfield or Greenstuff ??
I Tried EBC and They ATE The Rotors..EBC Refunded the Costs of the Pads..I Would NOT Recommend Them!
I Use Porterfields ...With Great results!
I Also Fab a Metal SHIM to help Brake Squeak it Works!
As Luke Stated Mintex is also a Great Pad....Several Choices!
Old Sep 12, 2003 | 10:22 PM
SungSmith's Avatar
Anybody know a Mintex retailer in the Los Angeles area?
Old Sep 15, 2003 | 12:05 PM
SungSmith's Avatar
Luke, Does Tirerack carry porterfields?
