285 35 18 rear tires and rims?
Old Aug 5, 2015 | 08:46 PM
biker349's Avatar
cl600
hi, i have a 2004 cl600. my stock rear wheels are 265 40 18. 9" rims with a 44mm offset. i am looking at some used 285 35 18 tires mounted on mercedes rims off a 2009 sl. i believe the sl has different offsets than my 2004 cl600. my questions are 1- will the 285 35 18 tires rub on my car? 2- will the offsets on the sl fit on my cl? 3-will i need a different offset other than the stock 44mm offset to run these larger tires?
i believe the sl has a lower offset number, not sure. would a lower, or higher offset than my 44mm be needed to mount these wheels on my cl?
thanks
Old Aug 5, 2015 | 09:04 PM
biker349's Avatar
cl600
i think the sl rear rims have a 35mm offset and my stock rims have a 44mm offset.
