e55 rims on a w209 CLK 500
Old Apr 10, 2004 | 03:13 PM
dmg1123's Avatar
Would these fit with no problem? 18x8 in the front and 18x9 in the rear. Tires are 245/40s in front and 265/35s
Old Apr 11, 2004 | 08:11 PM
Harris's Avatar
It is not recommended to put wheels for 14mm bolts on cars that use 12mm bolts.
The front tires are too wide, you might have a problem making turns. Especially when you lower the car, the front tires might rub the struts.
Old Apr 13, 2004 | 03:24 PM
toymr2trd's Avatar
So how do you know if the wheel requires a 14mm or a 12mm? Take my setup for example. I have the Iforged Seneka's but am NOT sure about the size of the bolts that I need. Kind of scared that I get the wrong size and jack up the wheels. Wheels have been sitting at my house for a while now. Please HELP.
