New pads and rotors burning smell and vibration at highspeed braking.
I just put on a set of powerstop ceramic brake pads and slotted and drilled rotors on my car. I did the initial bedding process after installing them all seemed well not one noise.. braking was fine. I was kind of babying the car around as far as braking but recently I took the car on the freeway (figured it had been enough time) and I was going rather fast then applied the brakes moderately aggressive (not an emergency stop by any means) and I noticed some brake vibration. I began to get ready to get off the freeway and notice that this vibration kept occurring with each brake pedal application all the way until I finally pulled off the freeway and pulled into a gas station. I check the brakes it was obviously the front ones that i changed they were hot and I could smell the burning brakes. Let it cool down and I tested it again and the vibration problem seems to have gone away although the burning smell remains. My question is, could this be because the brakes were not fully bedded and my stop at high speed finally did this or could there be some major issue with the braking system. This vibration issue has yet to repeat itself again and I did test it quite a bit after this happened. I am waiting to drive it again today to see if the burning smell subsided.
Sounds like some sort of fluid got on the pads. Did you bleed the brakes? How is the fluid reservoir?
Originally Posted by JohnnyC
(Post 7163952)
You should always spray cast iron rotors with "brake kleen" or a similar solvent. You shouldn't use harsh solvents on carbon ceramic type rotors because you can degrade the bonding resin. I go as far to clean the rotors with hot soapy water, dry then hit with more Brake Kleen. Excessive and unessary but thats my method.
So if you didn't remove the anti corrosion oil before installing you will not be able to bed in properly. You didn't say whicht brand rotors you used, but Mercedes, Italian Brembo, and Zimmerman rotors are usually shipped dry. If it has not occured again then the fluid has burned off completely. And you shouldn@ t run into anymore issues. |
(Post 7164045)
I wouldn't worry too much about it. If the pads are not cracked you should be good to go.
To my understanding pulsating or vibration symptoms usually point to air in brake lines. |
(Post 7165258)
Hi,
I own a C300 4Matic 2008 Benz and have not tune-up the vehicle since purchasing, the car is struggling to pick up speed. Perhaps does this mean spark plugs need replacing and if so does anyone has an idea of the cost, type of spark plugs, and should anything else been serviced with a replacement of plug. |
