FS: 18x9 Kosei drag wheels with tires
these are the now discontinued 18" x 9" kosei wheels weighing about 17lbs mounted on 265/40/18 Mickey Thompson drag radials.
i compared the MTs to a brand new set and they have about 50% tread left before getting to the wear line. these can probably be used beyond the wear line though since they are for drags. asking $700 for wheels and tires. http://img.photobucket.com/albums/v2...ak/photo-2.jpg |
Will they fit c63?? do u know what is the offsets?
This is a good drag setup.... and the low-weight of the wheel is incredible: 17 lbs for 18" wheels. I know of a couple of people who used to run the same setup with great results :y
yup they are a nice and light drag setup and i was able to get the current cls record with those on the car. if i had more time to practice with them i could have hit some 1.6x 60' times.
im not too sure if they would fit a C63 but they work fine on the E class. the offset is +38 |
That set up is money! We used the same set up and cut a 1.5 60' :bow:
Is this for 4 or 2? Where are you located?
this is for a pair of them.
im located in vancouver, bc canada. for american buyers, i can try to mail them from your side of the border to reduce shipping costs. |
Originally Posted by V12Godspeed
(Post 4080345)
i need more practice, if i could have cut a 1.5 60' i may have hit the high 10s! |
Are these wheels the same as tirerack kosei sales for $200 a piece?
im not sure what tire rack sells for 200 a piece but i do know that they no longer carry any of them in 18" size or even in our bolt pattern, apparently they have been discontinued for a while now.
Are you including the bolts and hubcentric rings?
sorry, no bolts or rings included.
the hubcentric rings were not needed when i used them and i used the bolts from my aftermarket rims to mount them. |
bump bump!
to the top!!!
I can't believe anyone hasn't jumped all over these yet. They no longer make the rim and it weighs only 17 lbs....:eek:. I have had some great luck with these tires and cut some solid mid 1.6's.
Good luck T on the sale and here's a bump for a stand up guy! |
thanks for the bump alan!
still available!!!
