Sponsored by: MB Part Haus
FS: 18x8 18x9 Staggered Rays Engineering Victrix Classic Hammer Style Wheels
Old Aug 29, 2014 | 09:51 PM
Demode1204's Avatar
1996 C36
I'm selling my 18x8 et35 18x9 et36 5x112 Rays Engineering Victrix wheels. I recently had the outer lips polished and the centers hand brushed with silver accents. I wasn't able to find new hardware so I had the existing hardware painted gloss black and retro fitted AMG badges on them (as a side note 75mm badges can be easily retrofitted).
I'm asking $1200.00 o.b.o and will include shipping anywhere in the USA.
Please note that on AMG models you will need a 25mm H&R Track Spacer for the front to clear the brakes which I can include at the full price. I also ran a 10mm hub centric spacer in the rear just to match the fronts stance.
For non AMG models you'll be good to go no spacers required (unless you want an aggressive fitment as shown above.
Old Sep 2, 2014 | 06:22 PM
Dan04mcs's Avatar
2002 E55
Were these origianlly 5x112 or have they been re-drilled?
What is the hub bore?
The bolts that were painted black, what were they origianlly?
Thanx!
Dan
Old Sep 2, 2014 | 08:01 PM
Demode1204's Avatar
1996 C36
Thanx!
Dan
Hello Dan,
The wheels where originally 5x114.3 and I had the local machinist tuner tap them to 5x112. I rode these on my car for 2 weeks and can tell you that even while running spacers I had absolutely no vibration.
The center bore is 73.1, I can accommodate hub rings if needed as I work for an online wheel distributor and have most hub rings in stock. The hardware was originally black just faded away.
What you looking to put these on?
Old Sep 2, 2014 | 09:43 PM
Dan04mcs's Avatar
2002 E55
W201 E55
The stock wheels are 18x8 et31 front, 18x9 et 35 rear
Center bore 66.56
What bolts did you use with them?
Old Sep 3, 2014 | 07:07 AM
Demode1204's Avatar
1996 C36
W201 E55
Center bore 66.56
The wheels are within range of your offset the only concern I'd have is your caliper clearance as I'm unfamiliar with your brake system. My C36 shared the caliper of an SL600 which is one beast of a caliper.
If your brake calipers don't extend outward as much as mine you'll be good to go. At worse you'd need hub centric spacers to clear them which unlike in my situation your body allows for more clearance than mine.
I used spline lug bolts like these: http://cdn3.volusion.com/5ehx2.gysj4...jpg?1375101646
If you want to measure your caliper clearance let me know and I'll send you some instructions.
Old Sep 3, 2014 | 09:57 PM
Dan04mcs's Avatar
2002 E55
Sounds good.
Old Oct 8, 2014 | 10:09 AM
Demode1204's Avatar
1996 C36
Dropping the price of these to $1000.00 shipped. If interested let me know.
Old Oct 13, 2014 | 09:45 AM
Demode1204's Avatar
1996 C36
Priced lowered $1000 shipped! Otherwise I'll store them for my next project.
Old Oct 13, 2014 | 02:22 PM
Lifeforce's Avatar
2010 w204 C63 AMG - 1998 S320 - 2008 R350
I'm interested as well for my 99 e55. What type of tread life on the tires? Will stock bolts work? Price without tires?
Old Oct 13, 2014 | 02:26 PM
Demode1204's Avatar
1996 C36
The price is without tires. The stock bolts won't work but I do have spline lug bolts that I had on them. The wheels are in mint condition. I'll be very frank with you though, I'm not sure if they'd clear your brakes as they didnt clear mine.
Old Oct 13, 2014 | 02:27 PM
Lifeforce's Avatar
You'll be including the spacers as well per what the initial post said, correct? What is the difference in bolts?
Old Oct 13, 2014 | 02:32 PM
Demode1204's Avatar
1996 C36
WOW forgot about that before I discounted. I spend another $260.00 just on those spacers being they're MB specific to our hubs. With the spacers you can most def clear the brakes. I'll keep my word on the $1000.00 including the spacers.
Old Oct 13, 2014 | 03:13 PM
Lifeforce's Avatar
Ok, so it'll include front and rear mb specific spacers so EVERYTHING is hubcentric correct? Just wanna make sure I'll need to double check my front clearance now just to verify it'll clear the brakes.
As for the finish on the faces, were they just repainted or powdercoated? Any leaks in the rims? Sealed properly? Bends?
Old Oct 14, 2014 | 08:40 AM
Demode1204's Avatar
1996 C36
I purchased the wheels on ebay with curb rash and had them rebuild by TornAssembly. He painted the faces silver than later had brushed the face leaving just the accents silver and he also refurbished the lips and re polished them. Oh and lastly he painted the hardware gloss black. The wheels are two piece so the outer and inner lip are combined (prevents leaks) and the face is bolted on to the barrels. If you PM me your email I'll send you pics of the spacers.
Old Oct 28, 2014 | 03:49 PM
Hound's Avatar
1996 C36 AMG, 2013 Dodge Dart Turbo 6spd
Are these still available?
Old Oct 28, 2014 | 04:59 PM
Demode1204's Avatar
1996 C36
Sure are. Just replied to your PM.
