Mercedes-Benz C-Class: Performance Modifications
The engine in the Mercedes-Benz C-Class is one of the most versatile engines Mercedes makes, which means there is a lot of room for improvement on your end!
This article applies to the Mercedes-Benz C-Class C250/300/350 w204 (2007-2014).
So you want to make your C-Class truly your own, but wheels and body parts don't truly add any performance. Good news! Engine modifications do. Unfortunately, the internet is filled with a large selection of parts and opinions that, for the most part, can't be trusted. Keep in mind that Mercedes uses a variety of engines for the C250, C300, C350, and even C63 AMG. They are very different, and one must pay attention when shopping for parts, especially if the parts are sold in a different country.
Performance Mods
For the 2007 to 2014 Mercedes C-Class, there is a wide variety of performance mods on the market. But the most common ones range from a simple ECU swap or tune to a more elaborate intake and exhaust install. The turbo 4-cylinder engine of the C250 is very different than the 6-cylinder of the C300 and C350, so always double check compatibility.
![](https://cimg0.ibsrv.net/cimg/www.mbworld.org/1024x651_85/924/AAApril-28-Performance-Mods-06-63924.jpg)
Tune/ECU
![](https://cimg0.ibsrv.net/cimg/www.mbworld.org/600x405_85/916/AAApril-28-Performance-Mods-03-63916.jpg)
DIY Cost – $1,200-$3,000 for parts
Professional Cost – $50-$100 for labor
Skill Level – Easy; it is a simple replacement.
Think of the ECU as the brains of the engine, and as such, it tells the rest of the components what to do. It will allow for a richer air to fuel mixture, and an increase in horsepower. It can even reprogram the transmission shift points to compensate for the added horsepower and torque. Multiple manufacturers produce these, so make sure to buy one with reviews. Some tuners require you to remove your ECU and send it to them for "flashing", while others give you a whole new ECU to plug into your car. Recommended for its richer air to fuel mixture, and horsepower increase.
Exhaust
![](https://cimg2.ibsrv.net/cimg/www.mbworld.org/600x400_85/918/AAApril-28-Performance-Mods-04-63918.jpg)
DIY Cost – $600-$2,900 for parts
Professional Cost – $1,100-$3,500 for parts, and $800-$1,200 for labor
Skill Level – Difficult; it requires specialty tools and knowledge.
The exhaust is the iconic mod that almost everyone performs, and for a good reason. The reason being the aggressive sound, as well as the increase in horsepower and torque. Depending on which model of C-class you have and the construction of the system, it could deliver extra 15 to 50 horsepower. Most exhaust systems require metal cutting and welding to be installed, so you may need to visit a shop for this install. The installation cost can vary depending on the difficulty or specialty level of the exhaust system. Recommended for its aggressive sound.
Intake
![](https://cimg0.ibsrv.net/cimg/www.mbworld.org/600x398_85/920/AAApril-28-Performance-Mods-05-63920.jpg)
DIY Cost – $150-$450 for parts
Professional Cost – $150-$300 for labor
Skill Level – Easy; most will be a bolt-on setup.
The air intake describes the air filter, the piping that air travels through, and all the way into the intake throttle body. But most commonly, it's referred to the air filter assembly. A performance air intake allows bigger amounts of cooler air, which in turn helps the engine produce more power. Most high end intakes will replace plastic for aluminum or even carbon fiber. Installing it is easy as most setups include bolt-on parts that fit the OEM layout. Most air filters included in an aftermarket setup are washable. So, not only does it make the air intake a cool mod, but also a financially smart one. Recommended for its easy installation.
Related Discussions
- Mercedes C-Class Performance Mod Discussion - MBWorld.org
- Performance Vath ECU Discussion - MBWorld.org
- Performance Modifications Discussion - MBWorld.org
