Mercedes-Benz E-Class: Recalls and Technical Service Bulletins
Read this article to find out if your Mercedes-Benz E-Class has been impacted by any recalls or technical service bulletins.
This article applies to the Mercedes-Benz E-Class (2010-present).
The Mercedes-Benz E-Class is an attractive, all-wheel drive, 7-speed automatic executive vehicle that boasts moderate to high fuel economy and is a great balanced ride. Rated favorably among Mercedes-Benz car buyers for its powerful engine, spacious interior and cutting-edge safety features, the E-Class is a triumph in performance, design and safety. Some recalls and technical service bulletins have been issued for the E-Class. However, the majority are small repairs that can be done in less than a day at your local dealer. This article will provide you with a list of the component(s) affected by each recall and explain the consequences for your vehicle. Let's get started with the list of recalls!
![](https://cimg1.ibsrv.net/cimg/www.mbworld.org/1446x846_85/25/s-class-w222-and-e-class-w212-win-auto-trophy-2013_2-68025.jpg)
Recalls
If a defect in equipment is discovered in any specific make and model auto, a recall is issued to alert the general public of possible safety risks. In the case of a recall issue, the manufacturer must offer the purchaser one of the following three things: repair, replacement, or refund.
2010
- NHTSA Campaign Number: 10V459000
- Component(s): Steering
- Summary: The loss of power steering fluid could cause driver to lose control of vehicle.
2011
- NHTSA Campaign Number: 11V496000
- Component(s): Fuel system, diesel
- Summary: Leaky fuel filter.
- NHTSA Campaign Number: 11V213000
- Component(s): Engine and engine cooling
- Summary: Inner mass damper ring could separate from the vibration damper.
- NHTSA Campaign Number: 10V540000
- Summary: Leaky fuel filter due to poor lubrication.
2014
- NHTSA Campaign Number: 14V762000
- Summary: Leaking oil around the chain tensioner gasket area could cause fire.
There were no recalls in the years 2012 and 2013.
![](https://cimg3.ibsrv.net/cimg/www.mbworld.org/800x600_85/23/leakyfuelfiltereclass-68023.jpg)
Technical Service Bulletins (TSBs)
A Bulletin, also referred to as a Technical Service Bulletin or TSB, is a general advisory issued to the customer by the manufacturer. If the manufacturer is made aware of a common or recurring default, they may issue a bulletin with detailed instructions on ways to avoid or solve the problem. Unlike recalls, these bulletins may not necessarily pertain specifically to safety issues. Bulletins discuss a wide variety of possible and common complications.
- NHTSA Item Number: 10038206
Service Bulletin Number: LI-27-50
Date of Bulletin: Jan 10, 2014
Component: Power Train (faulty RPM sensor)
- NHTSA Item Number: 10055433
Service Bulletin Number: SCB-2013110011
Date of Bulletin: Dec 01, 2013
Component: Equipment (missing supplemental operator's manual)
- NHTSA Item Number: 10052629
Service Bulletin Number: LI-82-10P-056479
Date of Bulletin: Jun 04, 2013
Component: Exterior Lighting (error in control unit headlamp)
- NHTSA Item Number: 10043811
Service Bulletin Number: LI27-20-P-051537
Date of Bulletin: Aug 07, 2012
Component: Power Train (jerkiness during gear change, hard 1-2 and 2-3 shifts, problems properly engaging torque converter lockup clutch)
![](https://cimg3.ibsrv.net/cimg/www.mbworld.org/667x418_85/27/rpm-speed-sensor-68027.jpg)
Common Questions
Who should I contact in the event of a recall?
Your first point of contact should always be your local Mercedes-Benz dealer. You may also contact a Mercedes-Benz customer representative at 1-800-367-6372 if you need further assistance. A representative can help you to set up a service appointment to have your vehicle inspected and/or repaired.
How do I look up a recall campaign for my vehicle?
The easiest way to look up a recall campaign for your vehicle is by going online. Visit the Mercedes-Benz website and enter your vehicle identification number (Refer to the link to the Mercedes-Benz website in the Related Site section below).
What should I do if my vehicle has been recalled?
Contact your local Mercedes-Benz dealer. If you would like to choose a preferred dealer, visit the Mercedes-Benz website and enter your VIN.
Who is responsible for any charges that occur as a result of a recall? What about a TSB?
If your vehicle is involved in a recall, Mercedes-Benz will cover the costs of any needed repairs. If a technical service bulletin is issued for your vehicle, you would need to cover those costs. The good thing about a technical service bulletin is it can reduce labor costs by reducing the amount of time your mechanic spends searching for a possible problem.
Related Site
- Mercedes-Benz Recall Search - MBusa.com
