Idling problem
Idling problem
Hello ,
My 190e shakes a lot when I come to a stop. When I drive it the car is fine this only happens when the car comes to a stop or low speeds. Any advice will be helpful.
Gday Mate
Did you find a solution to the problem as I have the same and curious to know what you have done to get rid of it?
When I start my car from cold its idling smooth, driving smooth, bur after about 20mins it start to "get the shakes" when I stop at a traffic light, and also when I pull away....However the car drive smoothy oce I`m on the move......Told it might be the distributor cap......Any advice or suggestions?
1993 Mercedes Benz 190E 2.6L
I was having all kinds of strange idle issues. I replaced my OVP and it runs and starts much smoother. I have come to find out, the ovp is very easily fried or damaged in these. They don't cost much so definitely worth replacing
OVP?
Hey mate
Thanks for your reply!
For me as a totally stupid with technical stuff, what is
a OVP and where is it located?
Maybe a pic perhaps, please!!
[QUOTE=s190e;6458540]I was having all kinds of strange idle issues. I replaced my OVP and it runs and starts much smoother. I have come to find out, the ovp is very easily fried or damaged in these. They don't cost much so definitely worth replacing[/QUOTE
OVP is a silver/gray relay behind the battery.
DON'T by this cheap relay's on ebay. It's much better to re-soldering the relay.
I did by a new OVP to my "190K". And as long I did use this with a newer EFI+++ & alarm did I find out that this are no good. Suddenly my alarm starts and the reason was that the relay did go on when it want,somethimes the car didn't stop. I did repair my old relay and everything are ok.
On a stock w201+++ can't you figure out this, only if your battery is empty,
Try the temp sensor sounds crazy rite? After a grand$
Try the temp sensor I know it sounds crazy I spent a grand chasing same problem ce down to that believe it or not lol190e;6288661]Hello ,
My 190e shakes a lot when I come to a stop. When I drive it the car is fine this only happens when the car comes to a stop or low speeds. Any advice will be helpful.[/QUOTE]
