190E (W201) 1982-1993: 190E 2.3, 190E 2.6, 190E 2.3-16, 190E 2.5-16, 190 D 2.2, 190 D 2.5, 190 D 2.5 TURBO, 190E 2.5-16 Evolution I, 190E 2.5-16 Evolution II
85 Mercedes 190e
Old 03-02-2015, 08:41 PM
mrmalin92's Avatar
85 Mercedes 190e
85 Mercedes 190e
I really love this car. I just got it about a month ago and I have fixed so many things. Its running quite nice now. I wanna move all the switches in the center somewhere else. The window switches, hazard and mirror adjuster. I got rid of the fader when I installed the headunit. Just wanted to know if I could buy a switch holder that was already done right. Thanks guys
Old 03-12-2015, 08:32 PM
MTI
MTI's Avatar
'85 190E 2.3-16 '99 C280 '11 GLK350
Curious, why do you want to relocated all the controls from the shifter area? There is no "pre-made" panel, so if your set to do this, you're going to have to fashion your own fascia plate and then slice in the wiring.
Old 03-13-2015, 12:17 AM
mrmalin92's Avatar
85 Mercedes 190e
I just believe it'll look better with them moved. I think I'm gonna try and put them where the ashtray is. It won't be as far of a move so it shouldn't be as hard as if I wanted to put them in the driver door panel. I'll just have to find a good material to make the switch holder out of.
Old 03-13-2015, 01:05 PM
MTI
MTI's Avatar
Okay. In your '85 the center console stack doesn't go all the way down like the later models do. I suggest that you consider getting a center console from the 16 valve, which is a direct fit and will give you much more space, including a double DIN compartment if you don't use the extra gauges.
Quick Reply: 85 Mercedes 190e
