DIY: New Chrome key upgrade/retrofit.
This DIY is to swap the ROM chip from the old plastic key to the new style chrome key, the result is a functional chrome key that will take place of the old key; you will not gain an additional key.
The key I use is from the 2006-2009 models with the round panic button. Ebay keys will work, just need to ask the seller if the key was tested and working, most of the ebay keys have cracks on the button, so ask and pay close attention to the pictures.
WARNING!!!!!! Do this at your own risk, not recommended if you have only one key and/or not have the proper tools and skills.
The procedure is as followed:
1. Open up your old key just as you would when you replace the batteries, do the same thing with the new chrome key, they are built the same way.
2. Pull out the PCB from the casing. On the old key, the board comes out easily by tapping the casing on your hand as you would do with a ketchup bottle. For the new chrome key, use a needle nose pliers grab on to the white plastic part and pull the board out.
3. Locate and remove the 30 pin ICs both PCBs, they look identical so make sure you mark the working IC from the old key. This is where skills and proper equipments are critical, you must not damage the boards or the chips. Also note the polarity/orientation of the IC, can be identified by a dot at one of the corners.
4. Install the old chip on the new board, make sure the chip is orientated correctly or it will not function, again special skill is required.
5. Clean up with electronics cleaner and dry your board completely with a hair dryer. Don't worry, you will not burn the board as long as you keep the hair dryer at least 8 inches from the board.
6. Reassemble and enjoy your new shiny chrome key.
Here is a picture showing which IC is to be swapped.
ATTENTION !!!! DO NOT BUY THE 2010 NEW STYLE KEY.
I have an update regarding the new 2010 and up key style with the triangular panic button.
I open one up today and was very disappointed as there is no interchangeable chip in this key to match up with the old key.
Apparently, MB had upgraded the PCB configuration, it is much simpler now with NO ROM chip that I can see.
Also, the casing is glued together so by the time you took it apart it will be in pieces; I had to use the ultrasonic tank to loosen the glue.
Damn MB engineers!!!!
purplecat001 (02-14-2017)
As I mentioned, you need special equipments and skill for this mod.
Please be extra cautious, do not attempt if you are not 100% sure.
06_ML350; 04_E320_4M
So, I remembered your solution described here and I need a bit of clarification: can you please PM me so that I can get this mod sorted out?
hey I'd like to replace the older style chrome key with the new style (triangle panic) how did you take the new one apart? I know you said its glued together but I bought a $20 one off ebay and I'm willing to attempt to get it apart and I'm happy to glue it back together but I just dont want to actually break anything
Many of the MB owners have/had problems with their old/current keys. The options for a replacement are limited to either a dealership (expensive new chrome style with triangle panic button), or some chrome style keyfob with round panic button.
You can buy the the later of ebay, then attempt to swap the guts (the one you just bought with triangle panic button cannot be swapped).
In my case, I had to replace the old style key fob as one of the micro switches was completely loose. I opted for the 2nd option, contacted dark_knight for the swap and soldering, and one week later I had my new chrome style with round panic button back.
I still needed to buy an uncut key blade to be re-cut here locally.
2010 Mercedes Benz GLK350 4MATIC
Key Fob Replacement
When I purchased my 2010 GLK, I received the Chrome Key Fob with the Circle Panic Button. Mine looks a little beat up. So I can order a New Chrome Fob w/Circle Panic Button off E-Bay and Swap the Guts then just get the Safety Key on the new Fob Re-cut Locally?
Thanks for Help Guys.......
Has anyone but the OP attempted this job successfully? I'm guessing you use a hot air soldering unit with some of that paste solder that shrinks down when you heat it up?
I'm looking for someone with the skills to do this but it's not easy. Obviously if you don't do it right you've bricked both keys.
key fob chip swap
Thought I'd pass on that I did this on my c320 and it worked perfectly. From years of tossing around my old key fob, the door "lock" button would work and it only started the car half the time. I purchased a new chrome key fob on ebay.
I do not have the tools or skills to do this on my own. I took it to a local TV repair shop and showed the picture above to the tech. I stressed that there was no pressure if it didn't work.....I would just purchase a new fob (~$200) from the stealer if it didn't. He charged me $30 and completed it in about 15 minutes. All buttons work perfectly and it started the car right up.
just to reiterate it doesn't work with the new chrome key but the FIRST chrome style key only, the one with flush buttons and a round emergency button. New key has a triangle emergency button
Hey, I want to change my key to the chrome one, but my old key is a two button one (Estate version) and I am not sure if the new 3 button chrome key will work on my car. Do you guys have any idea if it will work or I have to buy a 2 button chrome key? Below is a picture of my original key.
http://i.ebayimg.com/t/NEW-2-BUTTON-SMART-REMOTE-KEY-FOB-CASE-for-MERCEDES-BENZ-C-E-VITO-SPRINTER-ML-/00/s/NDgwWDY0MA==/z/vA4AAOxy-j9SSIvW/$T2eC16NHJHQFFhtL5IfjBSSIvV)t7g~~60_12.JPG
well, I did it and it will unlock the doors but not start the car.. I dont know if the key was defective to begin with or if I messed it up in the process. Back to finding another ebay key I guess and try it again.
W209, W124
I think that dark knight has posted before that Keyless go doesn't work
If anyone ends up with a dead smart key in a drawer here in LA I might be able to help you out. (In hollywood)
Sorry to bring this old thread back, but I was trying the OP's technique of upgrading the keys and noticed a difference.
The key I bought was of ebay and but is different to the OP's new key.
Notice the op's buttons for depress on the PCB are on the bottom side whereas the key I bought of ebay, the button's for depress are on the top side of the PCB.
The ops new key pcb is different than the one I got of ebay. Notice the difference in PCB designs.
The NEC chip on the new key also is placed at a different orientation than the old key. Notice the "circle mark" on the corner of the chip. That shows the position of pin 1 for the chip is the first pin to the left of that mark.
Il confirm whether this works.
W209, W124
If the Chrome body was in nice shape, you have the luxury of buying a crappy non-keyless go key instead of holding out for a nice one.
And to answer Hutchinson's question, same answer. I have not had the luxury of playing with KeyLess Go cars, but I can say with certainty that moving the NEC chip onto a Keyless Go Chrome key leads to a big NADA.
2000 S430
key fob swap
I have a 2002 Mercedes CL500 with a worn plastic key fob. So I purchased similar plastic fob off ebay and transferred the components over to it.
Now my car will not recognize my key, but my key can still lock and unlock the doors, and open the trunk.
I tried putting it back to my original fob, but got the same response.
My key was working great before the attempted swap.
The dealer wants me to buy a new key $325 plus $80 to reprogram.
Nobody around me wants to touch it, and the closest I got was a guy that wants to reprogram a new key for $350 or $250 if he can fix mine.
I'm in Ontario California. Anybody knows anyone close that can help at reasonable price ?
Thanks Guy's!
Thanks Guy's!
W209, W124
Kayca just left here on his way back to Ontario from my place in Hollywood. On inspection under a magnifying glass I could see a tiny hair of a wire poking off the end of the coil that powers the ignition part of key.
So I gave him the choice of moving the EEPROM to another PCB that he supplied for FREE or he could have a Chrome one I had from Ebay for $55.(what it cost me) He went with the Chrome one so I moved his chip over.
I was able to get the red lights flashing which usually means the key will work.
Fingers crossed !
If it works out I will post some pix of the 2 keys.
Fingers crossed !
2000 S430
Thanks a lot MacVidMB-V8. I got home, and walaaaaa the key worked !!!!!
For $55 cost as against dealer $400, my CL500 is back on the road.
You rock man ! I can't thank you enough. You are 5 Star !
