Rear turn signals 1998
Old 08-25-2014, 10:21 AM
236keith's Avatar
1998 C 230
1998 c230. Just bought this beautiful vehicle. Battery is dead. replaced battery and now my rear turn signals are not working but the reverse lamps flash instead? Is there a relearn process I need to do? They worked fine before all this battery problem happened. When I lock my doors with the remote the front turn signals flash...normal...but the rear reverse lamps flash also???help
Old 09-02-2014, 04:48 AM
Hashem.M's Avatar
W210 e240
I believe the tail lamp is hardwired so no learning,
tail lamp connector is irreversible, but have a look at them the might be reversed or tampered with (although this doesn't make any sense,because you said it worked fine before !
weird problem !
how did the battery die ?
Old 09-02-2014, 09:24 AM
236keith's Avatar
1998 C 230
reverse lamps
weird problem !
The battery died because of the cold weather and it was a 6 year old battery. I did not notice the problem at first. When I was checking the door locks with the remote unlock or locking I noticed the reverse lamps lite. Then just checking the tail lamp operation I then noticed when I activate the turn signals the reverse lamps were flashing. That's all?
Old 09-02-2014, 09:26 AM
236keith's Avatar
1998 C 230
The battery died because of the cold weather and it was a 6 year old battery. I did not notice the problem at first. When I was checking the door locks with the remote unlock or locking I noticed the reverse lamps lite. Then checking the tail lamp operation I noticed when I activate the turn signals the reverse lamps were flashing. That's all?
Old 09-02-2014, 12:40 PM
Hashem.M's Avatar
W210 e240
That's weird ! :S
i've never came across this issue before ! i'll think about it and read further more about this issue, meanwhile check the Fuses and connectors
Quick Reply: Rear turn signals 1998
