Fuse Box Map
Nike Turbo Shox
Yeah thanks bro I found it. My driver side door had just stopped working for some reason.. All the fuses were good and then it just started back working -_-. Then I remember that my car is very sometimeish.
Thanks for the quick response BTW.
Nowhere ...Fast
Here is a pdf of this...posted here on several threads https://mbworld.org/forums/c-class-w...-checking.html
#32
1 Post
1996 S420 2006 C55AMG 2002Mustang GT
hey i noticed an earlier response in this thread about someone asking what the electronic fuse meant. im in a similar situation. my car says my left liscense plate light is out when its not it blinks in a set sequence like its component related however the manual says the fuse for those lights is electronic. anyone have an idea on this i cannot find a clear answer and any help would be appreciated
#33
Super Moderator
hey i noticed an earlier response in this thread about someone asking what the electronic fuse meant. im in a similar situation. my car says my left license plate light is out when its not it blinks in a set sequence like its component related however the manual says the fuse for those lights is electronic. anyone have an idea on this i cannot find a clear answer and any help would be appreciated
#34
1 Post
im using the exact same bulbs oem specs. i even used my known good right bulb to test in the left light. please forgive my ignorance but what is the SAM. i have tried to clean the contacts but im not past trying that again. its just one of those little frustating things u know. and an excuse for johnny law to give me a hard time.
#36
Super Moderator
I have had an issue with my car not reporting an error on the right tag light when it is out and then also had issues with the left one having issues and that causing both to have issues so they are connected somehoe atleast on my car. I would say get some steel wool or an eraser ( I have heard it works) and give those conectors a good scrub and then get two oem bulbs from your dealer and put them both in just to rule out the bulbs compeltly. what year is your car?
#37
1 Post
its a 2006. i took a look at the sam module, all the fuses looked good but im wary of messing with the relays without a schematic. i have no idea which one controls the liscense lights. tomorrow at work ill prob try the steel wool. the internet really isnt showing me what is what on the rear sam so thats kinda a roadblock for me.
* i did replace both bulbs at the same time so the bulbs should be fine, and both work fine on the right light*
#39
Hi All,
my cigarette lighter and radio stopped working after I took out my car charger for the cigarette lighter.
i'm thinking I may have a blown fuse but I don't know where to find it?
Can anyone please tell me which fuse and the number I need to check?
thanks all.
thanks all.
#40
It under the hood (bonnet for you limeys). on left side of car.
See post 31 for the pdf that tells you the fuse #.
A bag of Spare fuses could originally be found with the spare tire.
There's a fuse removal tool stuffed into the styrofoam cover on the rear sam,
in the trunk, left side cover.
Peedi, to remove the cover by the left door, just pull it with your finger.Pops out.
#41
07 C230 (sold) 2009 E63 AMG (SOLD), 2015 E 63 AMG S
Hi,
What was the outcome of the lh front headlight not operating. After looking at the chart it says that the lh front indicator isnt a fuse its electronic??
Anybody got any ideas. My lh front headlight indictor stopped working and gave a fault indicator on the dash. THe bulb is fine as is the connections from the bulb holder to socket and harness to headlight assy.
any ideas would be greatly appreciated.
#42
1 Post
2002 C230 Coupe
Thanks for the list of fuses--troubleshooting a 2002 coupe I just bought because the remote lock is not working. I found fuses 9, 21, and 22 are in place, but 8, 32, and 33 are missing. Is there a chart that shows the value of fuses to go into those slots?
