Wagons Ho ! Let's see some W203 wagons.
Rating: Thread Rating: 5 votes, 5.00 average.
Old 02-18-2010, 07:50 AM
  #76
Midnight Koop's Avatar
CL203
wow... thats one nice c32 wagon. please keep us updated with your mods
Old 02-18-2010, 11:20 AM
  #77
glocati's Avatar
2013 ML350
Originally Posted by hanknum
OK, here's my wagon with the H&R Cupkit and Sport Sedan 17" wheels. The springs lowered the front about 1-1/2" and the rear about 1-3/8". To me it looks like the rear is sitting too low. What do you guys think?
I'm thinking I might go back to the stock rear springs and then install the thinnest pad (currently has the thickest). I also might experiment with the different lower shock mounts (Greg - you know what I mean). I don't really want to mismatch components, but I don't really have a choice. Unless, anyone has any other ideas of raising the rear with Cupkit.
Henry- congrats on getting it installed and also answering a question that has always bugged me, and that is: Does sedan specific supsension fit in the wagons. Looks like it does. How is the ride/handling?
Wagon looks great BTW. I think those wheels look killer on the wagons.
I see what you mean on the rear. It does sit a bit low compared to front. So, that is the thickest pads in the rear..the 4's-IIII? If, not, i know that's what came with my wagon and i will swap you if you need them. I was just under my wagon a few days ago and forgot to look at the rear lower shock mounts...dang it.
Anyhow, looks good and i bet handles a lot better now. Greg
Old 02-18-2010, 11:26 AM
  #78
glocati's Avatar
2013 ML350
Originally Posted by lepez
my wagon
c32 , quad exhaust.
and soon there will be a set of 19" bbs le mans. And hopefully a nicer suspension setup
wheels are gonna be repainted with a gunmetal centre and chrome bolts instead of gold ones...
grtz
lepez...thanks for sharing pics of your wagon ! Us wagon lovers here in the states drool over the thought of a c32 or 55 wagon as they never shipped them to the states. I am sure they are not to many in Belgium either for that matter.
Anyhow, great wagon. great color combination..and those BBS's are going to really put it over the top. Cheers, Greg
Old 02-18-2010, 01:06 PM
  #79
lepez's Avatar
CLS320cdi, GL350BT, ML270cdi
thx for the comments
i haven't got much plans anymore, except for the wheels and suspension ...
but actually, that's enough
@frankw: yeah, i don't know about the gold bolts ... color shoud come out nice, i hope at first i thought about keeping the color but i'm not sure..;
here is a pic of the wheels in front of the DD ( C220cdi )
grtz
Old 02-19-2010, 02:03 AM
  #80
hanknum's Avatar
'02 C320 Wagon, '78 308 GTS, '06 Highlander Hybrid
Originally Posted by FrankW
grats on the suspension
you can run thicker spring pads in the rear to raise it up a little. edit: re-read what you said...are you on #4 pads already?
Yep, I'm already on #4 pads. Do you know how much each of the different pads will lower? Usually it is not a direct correlation (ie 5mm thinner pad doesn't always mean 5mm lower ride height). I guess I will try different pads and also the different lower mount.
Old 02-19-2010, 02:46 AM
  #81
MBworld Guru
FrankW's Avatar
white and whiter
eh...i forgot which way's which...i think 4 dots is thickest already. they different by few mm each.
give it a search. splinter posted the info before.
Old 02-19-2010, 05:53 AM
  #82
lepez's Avatar
they are indeed different...
A 2103250184 is 5mm thick
0284 measures 9 mm
0384 measures 13 mm
0484 measures 17 mm
so the difference between is always 4 mm
grtz
Old 02-19-2010, 05:24 PM
  #83
hanknum's Avatar
0284 measures 9 mm
0384 measures 13 mm
0484 measures 17 mm
grtz
Yeah, I've got 0484 (the thickest pads). But how much of a drop would I get by going with let's say the 13 mm (0384) pads? I know it has to be more than 4 mm due to the geometry.
Old 02-20-2010, 01:38 AM
  #84
hanknum's Avatar
Handling is definitely improved but not to the extent I was hoping for. I'll probably go back to the stock rear springs with a thinner pad, but not sure if I'm going to go back to the stock rear shocks or keep the H&R shocks. I'm not real keen on mismatching the parts, but honestly, I think the H&R are slightly more damped, but not a lot.
BTW Lepez...nice car, want to trade?
Old 02-20-2010, 11:07 AM
  #85
glocati's Avatar
2013 ML350
Henry, that is a tough call as to what to do. Extra work, but i think you are going to just have try it (stock springs/HR shocks) and see how it goes...Good luck and keep us posted on it. Greg
Old 04-06-2010, 12:36 AM
  #86
hanknum's Avatar
OK, alls done. The front has been lowered 1-1/2" and the back just over 1/2". I've got the sport sedan wheels on off of an '05 and just put new rubber on the back (255/40-17). Handles much better and the ride is much firmer. This is still the wife's car otherwise the windows would be tinted, quad tip exhaust, and I'd upgrade the stereo.
First pic is stock for reference.
Attached Thumbnails Wagons Ho !  Let's see some W203 wagons.-mini-dscn0959.jpg   Wagons Ho !  Let's see some W203 wagons.-mini-dscn1332.jpg   Wagons Ho !  Let's see some W203 wagons.-mini-dscn1336.jpg   Wagons Ho !  Let's see some W203 wagons.-mini-dscn1337.jpg   Wagons Ho !  Let's see some W203 wagons.-mini-dscn1339.jpg
Old 04-06-2010, 10:58 AM
  #87
glocati's Avatar
2013 ML350
YES !!! Henry, that looks great. Sits nicely. After much trial and tribulation, i think you have it dialed in. You can probably swap springs/shocks in your sleep now
Congrats, look good.
Old 04-07-2010, 01:22 AM
  #88
hanknum's Avatar
Thanks Greg. Yep, if anyone out there needs a hand, PM me.
Old 04-07-2010, 10:23 PM
  #89
euromedic's Avatar
2002 C320 Wagon
It's been 8 months since acquiring the wagon.....
...I think we've settled into a nice routine with what is now called the Panzer.
Old 04-07-2010, 11:31 PM
  #90
glocati's Avatar
2013 ML350
Very cool to see you getting the same utility as i get out of my wagon. I tell ya, with the seat down, there is a lot of room.
Old 04-26-2010, 05:48 PM
  #91
Former Vendor of MBWorld
MBenzNL's Avatar
some slow@$$diesels
as I've always said, if only the C32 were available in wagon in the USA I would've gotten that.
...there is at least ONE...in designo mocca black , with a designo twotoned interior and designo wood...and distronic, keyless-go, MOST audio system - and so on...
greetingz,
Attached Thumbnails Wagons Ho !  Let's see some W203 wagons.-c32s203.jpg   Wagons Ho !  Let's see some W203 wagons.-c32s203a.jpg   Wagons Ho !  Let's see some W203 wagons.-dsc07997.jpg   Wagons Ho !  Let's see some W203 wagons.-rlc3242.jpg   Wagons Ho !  Let's see some W203 wagons.-rlc3245.jpg
Old 04-26-2010, 05:59 PM
  #92
MBenzNL's Avatar
some slow@$$diesels
I see that my old C270CDI wagon has been mentioned before...here are some more pictures - 2001 C270CDI station in designo silver, designo twotoned interior, cinamora designo wood and a couple of other nice (basic-need) features
unfortunately the car got totaled by my wife but at least she came out without a single injury and that is what matters most
greetingz,
Attached Thumbnails Wagons Ho !  Let's see some W203 wagons.-c270cdi04.jpg   Wagons Ho !  Let's see some W203 wagons.-amg6-4.jpg   Wagons Ho !  Let's see some W203 wagons.-amg6-5.jpg   Wagons Ho !  Let's see some W203 wagons.-203icstuff5.jpg   Wagons Ho !  Let's see some W203 wagons.-dsc06862.jpg
Old 04-26-2010, 06:08 PM
  #93
MBenzNL's Avatar
some slow@$$diesels
...and some pictures of the 2002 C270CDI wagon from one of my friends...also with some "basic-need" features...
greetingz,
Attached Thumbnails Wagons Ho !  Let's see some W203 wagons.-ms270gala01.jpg   Wagons Ho !  Let's see some W203 wagons.-ms270galc01.jpg   Wagons Ho !  Let's see some W203 wagons.-ms270galc02.jpg   Wagons Ho !  Let's see some W203 wagons.-ms270galc03.jpg   Wagons Ho !  Let's see some W203 wagons.-ms270gale01.jpg
Old 04-26-2010, 06:13 PM
  #94
MBenzNL's Avatar
some slow@$$diesels
...and some pictures of a norwegian C220CDI wagon I have worked on in the past...
greetingz,
Attached Thumbnails Wagons Ho !  Let's see some W203 wagons.-td220gala01.jpg   Wagons Ho !  Let's see some W203 wagons.-td220gala02.jpg   Wagons Ho !  Let's see some W203 wagons.-td220gald01.jpg   Wagons Ho !  Let's see some W203 wagons.-td220gald03.jpg   Wagons Ho !  Let's see some W203 wagons.-td220gald06.jpg
Old 04-26-2010, 10:34 PM
  #95
euromedic's Avatar
2002 C320 Wagon
Allemaal mooie autos MBenzNL
Old 04-26-2010, 11:27 PM
  #96
glocati's Avatar
2013 ML350
greetingz,
Steve/MBenzNL --Thanks for posting all the hot wagons. Your old wagon
(that unfortunately met its demise-glad the wife was not hurt !!! ) was the reason i got mine. I wish i had just a 1/4 of the awesome mods you installed in/on that wagon.
Cheers, Greg.
Old 05-02-2010, 11:30 PM
  #97
glocati's Avatar
2013 ML350
Thought I would share some more wagon pics.... even though the car is DIRTY ! Anyhow, I went for the "Stormtrooper" look on my wagon and had my TSW "Crofts" powdercoated a semigloss black. Also finally installed some clear headlights..halogen ... Also bought some clear fogs from Gary/advans that i hope to install soon. Cheers, Greg
Attached Thumbnails Wagons Ho !  Let's see some W203 wagons.-benz-025.jpg   Wagons Ho !  Let's see some W203 wagons.-benz-023.jpg   Wagons Ho !  Let's see some W203 wagons.-benz-022.jpg   Wagons Ho !  Let's see some W203 wagons.-benz-021.jpg   Wagons Ho !  Let's see some W203 wagons.-benz-020.jpg
Old 05-03-2010, 01:53 AM
  #98
XsuperbeeX's Avatar
C320 coupe
nice stance.. get the euro impact strips!!
Old 05-03-2010, 11:58 AM
  #99
euromedic's Avatar
2002 C320 Wagon
Very slick Greg
Old 05-03-2010, 05:03 PM
  #100
glocati's Avatar
2013 ML350
Thanks euro and superbee!
You have already rated this thread Rating: Thread Rating: 5 votes, 5.00 average.
Quick Reply: Wagons Ho ! Let's see some W203 wagons.
