M272 Intake Manifold
Old 05-10-2012, 02:36 PM
Keyless-GO's Avatar
2007 C230 Sport
Hi all,
have a problem with the intake manifold. Here is Link of engine: http://www.mercedestechstore.com/pdf...2008-05-04.pdf on 31 Page you can see front of intake manifold. There are 2 Longitudinal switch flap shaft one of that is broken so and my car lose the acceleration. I can not buy it separately MB Dealer only sell it with Intake Manifold so it too expensive. So can someone tell me can I buy it separately anywhere ?
Thanks Garry From Gerogia, Tbilisi
Sorry For My So BAD ENGLISH
Old 05-10-2012, 06:01 PM
Super Moderator
Glyn M Ruck's Avatar
This is a common problem on early M272 engines & Benz does not sell a repair kit. You need to buy the entire manifold. There is a long thread about the problem on the W209 forum. Your choices are new Benz, aftermarket manifold or a used one.
I don't know which rod has failed? Swirl flaps or manifold runner length. Your other option is to jam them in the position that you drive the most.
Old 05-10-2012, 07:39 PM
Keyless-GO's Avatar
2007 C230 Sport
12/4 Longitudinal switch flap shaft, left cylinder bank
This one is broken :|
Tnaks for reply
Old 05-10-2012, 08:56 PM
Super Moderator
https://mbworld.org/forums/clk-class...ld-broken.html
Old 08-07-2012, 09:47 AM
monoglobal's Avatar
2005 S500
I have replacement tumble flap lever for $249.00
Express worldwide shipping for $15.00
www.monoglobal.com.au
Old 08-07-2012, 10:11 PM
ncmudbug's Avatar
2005 C230K, 2016 Honda CR-V, '74 Lotus Europa
Originally Posted by Keyless-GO
Hi all,
have a problem with the intake manifold. Here is Link of engine: http://www.mercedestechstore.com/pdfs/287_R171/287%20HO%2003%20M272%20(FAH)%2008-05-04.pdf
Does anybody know where I can find a similar document for M271 engines?
Old 11-16-2012, 04:32 PM
wolf6755's Avatar
mercedes c300 2008 sports sedan
m272 intake manifold problems c300
you don't have to buy a new intake manifold if your linkage and flap are broken and Mercedes tells you to buy a new one for $1200.00 with Labor approx $2000.00 (that's CAD) a shop in Toronto called McNallys Auto has the repair kit and the whole thing runs about $800.00 forget the the Dealer
Old 11-16-2012, 06:39 PM
MBfinatic's Avatar
e36 318i, 2004 sti
If you need a manifold I have one. 33k on it. pm me if you want it.
Old 11-17-2012, 10:03 AM
Super Moderator
Yes ~ In SA we repair them as well. MBUSA will not allow dealers to repair them ~ hence no kit. In SA we just fabricate new parts.
Old 04-12-2013, 10:08 AM
tiisetso.leeuw's Avatar
2007 c230 coupe v6
Hi Glyn M Ruck, where in SA are they repaired, I am in Johannesburg and am in need of a fabricated part.
Old 04-16-2013, 11:53 PM
vikingmike10's Avatar
'06 C230 Silver (SOLD), '14 Black C250 Coupe, '16 Deep Ocean Blue Silverado
Wife was headed to work today and check engine light came on. She got off the fwy to see what was wrong. When she slowed down the motor got rough until accelerating again. Nothing visible after opening the hood (checked the oil and saw no visible leaks) and when she started the car again the light was off. Drove directly to dealer and they say she needs a new intake manifold because flap valve is broken - $2,800. They said that it is very dangerous to drive at all because the loose metal inside could get into the cylinder and cause major damage - is he blowing smoke? They also said they did an electronic compression check and all cylinders read about the same which indicates that there is probably no damage at this time. Got them down to $2,500 (he said parts are almost $1,600) but that is still pretty steep. Does anyone have any idea if that price is higher than normal? The car has 125k miles and I would love to not have to put that much into it. Would this be a DIY project or should I leave it to the pros?
Any help or advice is appreciated,
Mike
Old 04-22-2013, 09:33 AM
monoglobal's Avatar
2005 S500
Monoglobal replacement levers
I have the manifold lever in stock - no need to spend $2500 on a new manifold - you can purchase aluminum lever for $249.00 and I will include free shipping for MB World subscribers.
Will take any reputable MBZ dealer about 2 hours to exchange.
3 day express worldwide shipping from downunder Australia.
Click the link to buy http://www.cart.com.au/mono-global/view/2912/80564456/
Old 10-24-2013, 07:16 PM
Elto's Avatar
C 300 4matic
Repair kit on ebay for around $100.00 US
Old 06-27-2014, 09:05 PM
Hamoudeh-basal's Avatar
C230
Updates
I just picked up my car from the dealer cause I saw oil under on the transmission few days ago, and it turned out I have all these issues you all are having. Manifold flaps, which requires a replacement of the whole manifold ($2000) and the transmission speed sensor ($2200). besides other small things (Brakes and some other thing)
My questions are:
Has any of you actually tried the flap kit mentioned above (Found on Ebay for $108) instead of almost a $1000 for a new manifold?
Since these are such common problems, did anybody figure out ways around them?
I bought the car less than 6 months ago from a private party! It just 80K few days ago. Right now I have total of $4200 (Almost half what I paid for the car) on maintenance besides I need brakes (Rooters and pads)!
I am not sure what I want to do now.. A part of me wants to fix the car and a part of me wants to get rid of it!! Its a lot of money to spend on it right now and I will never get that money back
Old 06-27-2014, 11:18 PM
donlv01's Avatar
08 mercedes c350 p2
I have the same issue with my car! i'm ordering this part from all german auto... make sure you get the intake gaskets as well, your going to need to replace your old ones! oh and don't for get your going to need a torque wrench when you reinstalling the manifold...
here is the link:
https://www.agacoolantpipe.com/produ...throttle-lever
Good luck on the DIY
Old 09-14-2014, 06:38 PM
keithc230sport's Avatar
2007 C230 Sport
2007 C230 Sport installing a switch flap shaft
I am trying to re install the switch flap and the little cap that goes back in the block is giving me hell. I place it back in the spot where it's suppose to go and it will not stay. Help!!
Old 01-09-2015, 09:13 PM
ezkahuna's Avatar
Installed Aluminum Replacement part
I bought the replacement part from eBay for under $100. Came with two intake manifold gaskets. This really should be an MB shop fix instead of them having you replace the entire intake manifold (quoted from dealer around $2000. Quoted from private MB only shop at $1800). My part was broken exactly like the picture in the attached PDF shows. The fix is easy enough - and removing the intake manifold is okay too. The hard part is all the other hoses, bolts, wires, etc. that have to come off to get the intake manifold. Search YouTube. There are some very good instructional videos on there for the installing the aluminum replacement part. They show the fix but not really the amount of work you will have to put in to remove and reinstall the intake manifold. I paid my mechanic $600 for the repair job. The aluminum part WORKS!
Old 01-10-2015, 12:12 PM
pcy
pcy's Avatar
'14 ML350, '13 C220 CDI, '07 C280, '98 ML320
ezkahuna, did you find any instructions/DIY steps for removing intake manifold?
Old 01-11-2015, 12:56 PM
TYUS's Avatar
2010 E350 SPORT SEDAN, 2006 C280 4MATIC- SOLD 2009 FORD F-250, 2015 KIA OPTIMA HYBRID, 2013 MB E550
M272 MANIFOLD REMOVAL
THE LINK THAT DON (TWO POSTS ABOVE) HAS SUPPLIED SHOWS A SUMMARY OF HOW TO REMOVE THE MANIFOLD.
IT LOOKS PRETTY EASY TO DO.
I'M AT 88K MILES AND SO FAR, NOT NEEDED TO REPLACE THIS PART.
-GOOD LUCK
Old 01-11-2015, 06:28 PM
pcy
pcy's Avatar
-GOOD LUCK
The document/link states "Remove Intake Manifold. Refer to Mercedes Benz Procedures."
I am looking for instructions for removing the intake manifold.
Old 01-12-2015, 04:11 PM
cvx
cvx's Avatar
W203 C200CDI
I had my flaps removed from the intake after it started to leak oil. Flap motors still work and the construction has been slightly modified so STAR does not give any errors.
Applies for CDI-engines. Same has been plaguing BMW diesels too... rubbish quality for both brands
Old 01-15-2015, 12:14 AM
TYUS's Avatar
REMOVING THE INTAKE MANIFOLD
AT THE END OF THIS YOUTUBE VID:
- HE SUMMARIZES ABOUT REMOVING THE MANIFOLD TO WHERE I CAN UNDERSTAND IT; CHECK IT OUT...
Old 01-21-2015, 12:10 AM
jpman's Avatar
2009 E63
I've been using a tumbler on my brothers car that I made out of a thermoplastic compound. I basically over tested it once I was happy with the shape and definition at temperatures much higher than exposed and it has held pretty well. Would anyone be interested in this piece say if it sold for $60 with lifetime warranty? It would be an American made product if it matters to anyone. I might be able to make some if the demand is there.
Old 07-02-2015, 07:28 AM
Mangle's Avatar
2006 C Class C 230 Coupe 2.5l V6
Tumble flap
Hi Glyn, do you perhaps know where I can go in Cape Town area to have this flap fabricated or fixed. I'm driving a C230 Coupe. The car is still driving, I just can't drive at high revs.
Old 07-04-2015, 03:44 PM
jmustonen's Avatar
MB C230 2007
M272/273 Intake Manifold Replacement
My intake manifold also broke on my MB C230 2007 at 200 000km (125 000 miles). I got my manifold about 600 euros (OEM Pierburg part) and changed it by myself. I also made a complete walkthrough of the replacement job and people planning to do this as a diy project can check it out from here:
Part 1: Replacing MB M272 Intake Manifold Part 1 of 2 - YouTube
Part 2: Replacing MB M272 Intake Manifold Part 2 of 2 - YouTube
Problems were very rough idle, jerky transmission, misfires, check engine light again and again, poor mileage, bad performance.. you name it.
I am not a repair professional but I have little understanding about engines and I know basics how to hold tools. I was able to do the job succesfully and my car is now like it was on it's glory days couple of years ago. All the problems are now gone. I love to drive it again!
It might be that MB does not provide parts to the manifold because it becomes a complete wreck from inside, not just the outside levers fails..
You have already rated this thread Rating: Thread Rating: 1 votes, 4.00 average.
Quick Reply: M272 Intake Manifold
