Mercedes-Benz Srs Airbag light
Old 09-10-2012, 05:49 AM
Getoar's Avatar
Mercedes-Benz C-class
Hi. I have Mercedes-Benz C180 Kompressor 2003.I celaned the enterior with water(only seats) and after i finished the srs airbag showed on board computer.I was at the Mercedes-Benz service and they said to me that it s to expensive and maybe we have to change the sensor because it s damaged.Can i know what do i have to do to fix it.Is it true that now airbag is fault or what? Thnx
Old 09-10-2012, 12:46 PM
LILBENZ230's Avatar
2019 G70 6MT & 2022 Ford Maverick XL
You cleaned the seats with water? How do you mean? Do you mean you used a damp cloth, or do you mean you soaked the seat?
There is a sensor in the passenger seat tied into the SRS system. Water and electronics don't mix. If it got wet you'll need to replace it.
Old 09-21-2012, 10:49 AM
ilde10's Avatar
07 w221 s550 4matic
what about for the 07 C280? should i check the same spot? i have the same issue with the SRS light.
Quick Reply: Mercedes-Benz Srs Airbag light
