Whining noise on acceleration
Mercedes c180 coupe auto 2001
Hi, hope someone can shed a little light on this. I have a 2001 Merc c180 coupe auto petrol, only do 70,000 miles and drives like new. The only issue is when I'm on a motorway, going say 60mph with foot off the accelerator, then press gradually, there is a whining/smooth rumble from either underneath or to front, if i let off the gas a little it stops. not noticeable on 'A Roads' Only seems to happen when in drive accelerating but not hard.
Any ideas?
Cheers
Paul
Any ideas?
Cheers
Paul
Super Moderator
Does it happen when you are stationary & rev the car as well? If so it could be a torque converter.
If not check rear transmission mount, Flex discs on the propshaft & centre propshaft bearing. Meke sure that exhaust shield are not touching anything.
Can also be a diff pinion bearing that has lost preload.
When last was the transmission serviced. s/b every 39K miles or 60K Km's. Check fluid level.
