2001 W203 C200K (M111.955 engine) Help needed :(
Old 11-27-2014, 10:52 AM
sprockett's Avatar
Hi all,
My W203 C200 Kompressor (2001, M111.955 engine) has a noisy belt.
Unfortunately I don't have access to good independent mechanics, and the stealership will charge even more. So I have no choice but to DIY.
Searching online, the problem is likely one of the following:
-belt tensioner pulley
-idler pulley
-steering pump
-aircon compressor pump
I am facing a couple of problems:
1. Can't find repair manual for this particular car / engine combi. I've seen W203 Service manuals (haynes + merc DVD) but they are for the M112 engine variation (USA).
2. How do I find the right parts to give me the parts specific to my model?
I've been searching online for a few hours to no avail!
Appreciate any guidance.
Thanks!
Old 11-27-2014, 12:36 PM
KSKarl's Avatar
2002 C230 Coupe
Easiest way to check is to remove the belt, then spin each pulley to see which is making the noise. You pull the air filter housing to get access to the belt.
Old 11-27-2014, 01:06 PM
sprockett's Avatar
Hi KSKarl,
Thanks for the reply!!
Would this be the air filter:
2001 W203 C200K (M111.955 engine) Help needed :(-kpsjcji.png
If so, would you be able to suggest any search terms I could use to find the disassembly instructions?
In the last hour of more searching, I've realised that the M111.955 engine is also on the C230K Coupes (early 2000s). So I've also tried searching for C230K repair manuals, but to no avail.
Latest thing I've found are the WIS / ASRA manuals on Ebay, which I've gone ahead and purchased, but they will take some time to reach me.
Old 12-01-2014, 09:36 AM
KSKarl's Avatar
2002 C230 Coupe
Yes, that's the air filter. Disconnect the air ducts from both ends to remove it.
Sorry for the late reply, I was off line for a few days.
Old 12-01-2014, 09:40 AM
KSKarl's Avatar
2002 C230 Coupe
Pushed the wrong button there...
After you get the air filter housing out, pull back the belt tensioner to get the belt off. Then you can see how each pulley spins.
Old 12-12-2014, 11:48 PM
sprockett's Avatar
Thanks KSKarl,
I managed to do this and it was teh steering pump bearing that was shot.
Replaced it and things are good
Thanks again.
Old 02-24-2017, 11:38 PM
chanyat123's Avatar
C 200 Kompressor
KSKarl,
I have the same problem, but I do not know how to get the air filter housing out. You said that( Pushed the wrong button there....) what it means ? there are three grommets underneath of housing .Can you give me some crack method. Thank you very much!
Old 02-25-2017, 01:33 AM
C230 Sport Coup's Avatar
C230 Sport Coup + 2006 W164 ML350 + 99 Ford Escort (What the heck, it gets 38 mpg!)
Pull. Assuming we're talking M111 here, just pull up hard.
Remove the bolt on the plastic intercooler hose, and the intake clamp and pull.
Originally Posted by chanyat123
KSKarl,
chanyat123 (02-26-2017)
Old 02-25-2017, 08:13 AM
chanyat123's Avatar
C 200 Kompressor
Thank your quick reply, I will try to do it and report later.
Old 10-03-2017, 04:33 AM
huotalicusC200K's Avatar
w2010 w204 c300 amg sports package
need help removing the air filter hoiusing
Originally Posted by sprockett
Hi all,
-idler pulley
-steering pump
Thanks!
hey sprocket how did you manage to remove the air filter housing
I'm having trouble getting it out I have removed the clamp that hold it to the supercharger silencer but still cannot remove the housing assembly
can you help me or anyone help me please
Quick Reply: 2001 W203 C200K (M111.955 engine) Help needed :(
