Mercedes w203 c200 cdi low working temperature
Old 03-13-2015, 03:15 AM
ljupco81's Avatar
w210 e200cdi
Unhappy Mercedes w203 c200 cdi low working temperature
HI guys... while ago i bought C-klasse 200 cdi from 2001 t-model with 115 hp.
The working temperature on the car was little above 65 celsius degrees, so i
went to service and change the thermostat.
On first drive was OK, and now after 2 days its same like before changing the thermostat...
Did anyone has that problem ???
Please help....tnx in advance...
Old 03-13-2015, 07:52 AM
triffer's Avatar
2003 c class coupe 220cdi
2003 c class 220cdi sports coupe uk spec
on this car it has a heater assist to warm the water located above the starter motor when it goes relay jams on gives a flat battery approx £200-300 for the part starter need removing to replace i believe its a known fault lot of people disconnect them the AA did mine runs at 65-70 now was 80 but uk dont have to many cold winters note if is that and you reconnect it your battery will be flat in 4hrs you need an amp drain tester to see if pullinf 14amps or 30amp when ignition off might not be this hope it helps...
Old 03-13-2015, 08:16 AM
ljupco81's Avatar
w210 e200cdi
Is there a chance my car gone that part (heater assist) ?????
can you give me the location more precise...
Old 03-13-2015, 09:13 AM
triffer's Avatar
If your car has one possible mine os located directly above the starter motor small black plastic cylinder i used mobile phone on record to see it from underneith the car if its disconnected the wire will be removed and taped up as mine is.
my understanding is it works like a kettle warming water when needed in the mornings and when temp drops using a relay located inside the housing to switch on and off but the relay goes as there is a lot of heat in there. worth a look i guess but not to sure about the 200tdi..
Old 03-13-2015, 11:21 AM
cvx
cvx's Avatar
W203 C200CDI
I have same C200CDI.
Your car has 2 (two) thermostats. Change the other one too and your car will warm faster. The heater booster (can be activated in car settings) is guaranted to fail in every single W203, dont spend $500+ to fix it please.
The 2nd thermostat is behind the horns. About 5min job to change and you need hose pliers for that operation. The part itself is about $50 from the dealer.
Here are pics of mine when I changed it. (spilled some lol)
Mine temperature was stuck at ~60 too even with new OEM thermostat but now it gets to 90 when changed that smaller one. Still need to drive about 10km tho because the heater booster is dead
Old 03-13-2015, 12:00 PM
ljupco81's Avatar
w210 e200cdi
After one hour looking and reading here to posts, i found that on my car is MISSING recirculation pump (heater booster)...
could be the problem i am looking for ????
or should i look for the second termostat ????
Old 03-13-2015, 02:06 PM
cvx
cvx's Avatar
W203 C200CDI
Hey, you can see the 2nd thermostat when you open the hood and its right behind the horns in front of the radiator, see my pictures.
And the recirc. pump is also visible next to the cooling reservoir. I also changed that pump earlier since it was dead. also $50 part and easy fix
I can almost make a bet you have them both since I have the same year and same engine than you. And yes if the 2nd thermostat and the pump are dead, your car will not warm fast
Old 03-13-2015, 03:46 PM
ljupco81's Avatar
w210 e200cdi
No i dont have the circulation pump,
Its unmounted, but the second thermostat its on the car...
Probably its not working...
the main thermostat is new...
Could be the problem missing pump to engine running at 60-70 celsius degrees ???? Every time ???
Or the second thermostat ???
Old 03-13-2015, 05:54 PM
triffer's Avatar
Think ill be looking for the 2nd thermostat now great info..
Old 03-13-2015, 05:59 PM
triffer's Avatar
I think if the heater assist had gone or does it flattens your battety so id go with the second thermostat like previous post suggests if your hearer assist is gone id leave it disconnected as it is bound to go again.
Old 03-19-2015, 06:42 AM
ljupco81's Avatar
w210 e200cdi
I took out the thermosat(the second) and checked, while the engine was cold and noticed that liquid misses from both sides...
I think when is cold, should not miss liquid from both sides...
is that a problem ???? or thats the way it works ???
Old 03-19-2015, 06:45 AM
ljupco81's Avatar
w210 e200cdi
And one more question ?
Can somebody tell me where I can find to buy this part ??
EBAY ??
or ????
send me link
tnx
Old 03-26-2015, 04:20 AM
triffer's Avatar
is the thermostat genuine part? Main one reading posts the aftermarket ones are not to good mine does not have the 2nd one as far as i can see
went europarts and got a thermostat for £21 and turned out to be not the same had to get one from dealship that cost £48 inc gasket and v.a.t. so happy i did not had a chance to fit it yet but going by the 100s of threads on the subject its a common problem plus check you mix antifreeze to water ratio is correct.
that all i got for you sorry😕
Old 03-28-2015, 07:16 PM
triffer's Avatar
Changed thermostat today what a diffrence 65-70 was running at warn heaters inside now 92ish fuel mpg up by 7-9 mpg round town not smokin under heavy pedal Heaters are cooking hot.
Old 03-28-2015, 07:27 PM
ljupco81's Avatar
w210 e200cdi
Your car doesn't have the second thermostat ( the small one) !!!?? Its that ok ? I mean, you have no problems in cold weather ???
Old 03-28-2015, 08:29 PM
triffer's Avatar
No as i can see just the one in the uk so colds not to bad but from what i read should be 90 normal running temp takes a lot longer to cool down when stopped i.e. go shoppin come back and the engine temp still at 50-60 cant believe the diffrence..
Old 03-29-2015, 03:05 PM
triffer's Avatar
Did you fit a genuine thermostat from mercedes as aftermarket could be dodgy..
Old 04-06-2015, 02:20 PM
ljupco81's Avatar
w210 e200cdi
went to service today and mount recirculation pump...BUT ITS NOT WORKING
while it is in good condition (checked before)
Is there some way to TURNING ON and OFF ??
or it should be working every time when start the ignition.... ??????
Tnx
Old 04-06-2015, 02:41 PM
ljupco81's Avatar
w210 e200cdi
and one more information that makes me confuse !!!!!!!!!
are recirculation pump and heater booster the same part ????
Please some answer me becouse i am tired for looking the problem...
Old 04-07-2015, 04:46 AM
triffer's Avatar
The heater assist is on top of starter motor and warns the water up in the morning as for the reserc pump not sure if you mean water pump but google it and pulls up all threads from there but only thing is if resurc pump or water pump fail surly they will make the car run hotter not colder
other things affect engine temp running to cold is anti freeze summer coolant mix to strong thermostat constantly open as far as i know...
Old 04-07-2015, 06:29 AM
ljupco81's Avatar
w210 e200cdi
Do you know, if there is a way recirc pump turn ON and OFF ??
Or if works every time when engine runing ?
Old 04-07-2015, 07:27 AM
triffer's Avatar
Not sure m8 to be honest must be on the net somewhere ..
Quick Reply: Mercedes w203 c200 cdi low working temperature
