Dead alarm siren
W203 01' C200k
Dead alarm siren
Hello, the problem with the fuse nr. 8 blowing all the time occured to me today, so I traced the problem to the alarm siren behind the front wheel RHS.
I unplugged the plug and it's "fixed" for now.
But in order to get my alarm functioning, is it possible to just replace the battery, or do I have to replace the whole unit?
And does anyone know if you replace the rear sam unit (preface) to an unit from a facelifted W203 model, do you have to reprogram the sam unit in order to get the alarm up running?
I replaced this unit about a year ago to a facelift unit, and had to reprogram the fuel gauge sensor in order for the fuel gauge to read again. But I was wondering if I have to reprogram something about the alarm as well to fix the alarm? Or does it have the exact same address etc. as on the pre-facelift unit?
Thanks in advance.
Thanks in advance.
W203 01' C200k
Okay, so when I replace my alarm siren it will work again, without recoding the sam? Even if I originally had a prefacelift sam unit, but now use a facelift sam unit?
Dead alarm siren
It should work yes. If not just have it coded. Anyway coding will be blocked if siren is faulty. So first step is replace siren
