2007 C230 Misfire code won't go away
Old 08-19-2015, 12:17 PM
scottgerlach1's Avatar
2007 C230
I am having issues on start up that car will misfire after driving 30-60 seconds. After checking codes had multiple issues. I replaced Cam position sensors, All cam adjusters, Smog pump with relay, purge valve selenoid, and corrected a mis alignment of the engine cover. This cleared all the numerous codes. Now I only get the general misfire code. It always resloves if I stop car and re-start after driving. Car performs normal after that and usually averages >28mpg. Any suggestions for where I should go next for correction of this issue?
Old 08-19-2015, 04:44 PM
Kazi04's Avatar
2004 C230 Kompressor Sport
Did you replace any of the coils?
Old 08-19-2015, 05:06 PM
2007 C230
I replaced all plugs but no coils.
Old 08-19-2015, 05:18 PM
Kazi04's Avatar
That would be my next step in the process.
Quick Reply: 2007 C230 Misfire code won't go away
