Droppped my car key in the water........ What to do?
Old 11-21-2004, 07:13 PM
LWL
LWL's Avatar
2005 C230K, Lexus GS400
I accidently dropped my car key in the water, and now, the key only works to open the doors and truck, but can't start the engine (can't even turn). Is the car key replaceable?? WHere can I get the replacement?? Helppppppp
Old 11-21-2004, 07:20 PM
Administrator
amdeutsch's Avatar
MPG+ ROLFCOPTER
No its not. You need to get a new car.
Dealer :p
Old 11-21-2004, 07:32 PM
Capt Nemo o2's Avatar
'05 C230SS 6MT, 1966 Triumph TR4a IRS, Shelby Cobra 427 Supercharged
As the resident SCUBA diver at my yacht club, I have alot of experience with things falling in the water and retrieving them. If the key fell in saltwater, if you open it up and rinse it off in clean fresh water ASAP, then let it sit apart and dry, and replace the battery(s) its very likely it will work again. If it was fresh water, take the key apart, let it dry, and replace the battery. Its worth a shot. It worked with, numerous cell phones, beepers, a CD walkman, and a key for a Porsche!
Old 11-21-2004, 07:35 PM
mick1's Avatar
2005 C320wz
Dealer :p
That would be very cool if the insurance company would pay for the new car
Old 11-21-2004, 08:58 PM
kaze81's Avatar
Mercedes
The key is replaceable You can go to the dealer but I dont know how much you will pay and I am not sure if it will cover under your warranty. Mine happened last year and I got replacement under warranty.
HTH
Old 11-21-2004, 09:10 PM
djantlive's Avatar
You can remove the battery and try to let the inside dry for a few days. If it still doesn't work, you may have a short inside.
For replacement, you are looking at a couple of hundred bucks to replace each key from the dealer. Call a number of dealer around and compare prices. I think they may need to activate the key (not sure) so you may have to pay some labor besides the parts.
Old 11-22-2004, 12:41 AM
CitronC230K_03's Avatar
2003 Citron Green C230KMT
my keys about 8 months apart from each other, "happened" to fall in salt water with the batteries removed. soaked for about 10 min. then were rinsed in fresh water. allowed to dry for a day, put the batteries back in, didnt work at all anymore. took it to the dealer and got a new key. one with a trunk button on it, and it was covered under warranty. :v
Old 11-22-2004, 02:44 AM
LWL
LWL's Avatar
Do you actually tell the dealer that your key was dropped into the water?? I mean, if you dropped it into water, how can it be cover under warranty? What did you actually tell the dealer to replace your key?
Old 11-22-2004, 03:27 AM
brabusCcoupe's Avatar
Talking
I accidentally washed my key before and it still works fine, but im also wondering if you told the dealer it was water damaged and they replaced it under warranty. If so, how long is the key replacable under warranty because to get a new one it runs 150.00. Thanks
Old 11-22-2004, 06:08 AM
MBworld Guru
FrankW's Avatar
white and whiter
why the heck would you tell them the "truth" ...
just clean it and dry it and tell them it doesn't work somehow.
Old 11-22-2004, 06:29 AM
Talking
Thats what i thought Frank LOL I guess they dont check it for water damage then, huh?
Old 11-22-2004, 06:42 AM
MBworld Guru
FrankW's Avatar
white and whiter
the dealership could care less...not to mention the service advisor. all they care is to get as many parts replaced as possible. that way they get more commission. it is MBUSA spending the money to fix our cars anyway.
Old 11-22-2004, 07:16 AM
Talking
How long is the key actually covered?
Old 11-22-2004, 03:10 PM
Saprissa's Avatar
Location: San Diego, CA & San Jose, Costa Rica & Stuttgart, Germany
1959 220S / 1979 230 G / 2002 A210 AMG / 2003 C320 SC / 2004.5 C320 SS / 2005 ML350 SE / 2008 smart
Weird how that "happens" !
That exact thing "happened" to me too ! and I got a new 221 series key with trunk unlock button too for my Coupé replaced under warranty !
I think it's almost time for my other key to fall in some salt water with the batteries removed....
ssshhhhh
As long as your car is still covered by warranty.
Carlos
Saprissa@aol.com
Old 11-22-2004, 03:48 PM
LWL
LWL's Avatar
How exactly can you open the smart key?? is there any tricks or instructions that you guys can help me? Didn't want to break the keys and let the MB dealer has a chance to rip my $$$. Thanks alot
Old 11-22-2004, 04:36 PM
Saprissa's Avatar
Smart Key disassembly directions....
1) remove the metal glove compartment/trunk key by sliding release and pulling out.
2) you will then see a grey-colored spring mechanism that can be pushed back inside where the "handle" of the metal key would normally sit.
3) you kinda need 3 hands to do this, but with a small object (the metal key itself), push on that grey-colored piece, and with your fingernails, pull up on the seams (edges) of what looks like the lid or top of the SIEMENS smart key.
4) once that lid is pried open, you can pull it out, and you will see the 2 batteries held in place by a thin metal strip. (CR2025 3V)
5) to remove the batteries, look on the ( - ) side, and you will see a small tab that holds the thin metal strip in place. Carefully, depress this tab to release the thin metal strip that holds the batteries in place.
6) If you look inside the plastic casing of the Smart Key, you'll see the green circuitry card, that is very susceptible to "salt water".
Carlos
Saprissa@aol.com
Old 11-26-2004, 10:03 PM
gaiex's Avatar
'08 CLK320CDI AMG// '13 E500 Coupe AMG// '17 E350d AMG
How many keys do you have in US??
I have 2!!!
Quick Reply: Droppped my car key in the water........ What to do?
