Official Part Numbers Thread
#376
'09 C300 4matic (w204)
hey, i am currently looking for the bosch part number for the voltage regulator for my 09 c300 4matic, thanks
#377
c230 mercedees / 1969 beattle buggy
front differential noise / part number
Can anyone help with finding a part number for the bearings or a used differential box?
Hello, this is my first time on any car forum. Please excuse my ignorance of terms etc.
I have a 2008 c230 Mercedes.
it has a Front differential grinding noise. Diagnosed as the barring. When I drive I can hear the grinding noise. The faster you go the louder it gets.
Mercedes wants me to change the whole transmission (saying that is the only option)
Reading some of the threads for other models - It seems like people have changed just the bearings.
I have been told all sorts of things like the differential box cannot be opened or it is connected to the transmission and cannot be separated etc etc..
Anyone know if the box can be opened and if the bearings can be changed? Even better - anyone know which bearings I need so I can find a mechanic that can order and fix.
I want to make sure I do not cause more issues and cost then needed.
It would be great to be able to take the information to a mechanic and show them that is what would work.. As most do not seem to have too much experience with this issue.
I am worried that something will break in there and cause more damage if I don't get this fixed ASAP
Thanks for your help.
#378
Differential bearings - please help
Can someone please help with a part number, been at this for over a month with no luck.
I have a 4matic c230 2008 Mercedes. They never made this in the states - its a Canadian Car.
My front differential bearings are damaged.
Any help on part number or where I can order them would be so appreciated.
Thanks thanks
Thanks thanks
#379
2007 c200k rhd w204
Does anyone know the part nbr of the following for the above vehicle
Hood struts
Hood release cable the one you pull thru the grill
Master brake cylinder
Thnks in advance
Hood struts
Thnks in advance
#380
Front differential bearings
Can anyone help with this part number please - I am having a very very difficult time finding it for this specific model and year.
FRONT DIFFERENTIAL BEARINGS
2008 c230 Mercedes
4 matic
Vin # WDDGF85X88F163625
I live in british columbia, Canada.
I have been at this now for 2 months.
Would someone advice if it is a good idea to take it a part and then use the number on the old bearings to find the right one?
2008 c230 Mercedes
4 matic
#381
Hello,
I am looking for the Carlsson exhaust for my W204 (2008).
See the link beneath.
http://www.carlsson.de/carlsson/en/p...class_w204.php
Where can I find these or who can make those Exhaust for mine Benz, any idea?
#383
2008 c230 Mercedes
4 matic
2008 c230 Mercedes
4 matic
Inside=209 350 00 49
Outside= 211 350 04 49
Seal= 221 353 03 59
#384
C300 '08 Sport sedan
Hi Everyone,
This is my first post here! Not sure if this has been asked before but I'm looking to replace a B pillar front passenger side for my c300 year 2008 sport sedan. I actually found the part number but there appears to have two numbers on it so I have no idea about the differences. They are A2046900287 and A2046902687.
Another thing is that my driver door handle and passenger rear are having scratches and color fading. Do any of you know if I can order new door handles with painted color already? my car's color is mars red.
#386
W204 AMG PLUS 4MATIC
Hello, anyone can help me, with rear right inner fender, i am looking for the part number for a c350 cdi 4matic sedan? i have found this 3 part numbers (A2046906330 - A2046905330 -A2046902130) but i dont know which one is with the heating metal cover on like photo below.
#388
Part number for rubber cover for torque converter
Hello,
While doing the trans service on my '10 C300 4Matic, discovered that the rubber cover on the bell housing to the torque converter drain plug (little access window) is missing. Anyone have knowledge or ability to pull this part number?
#393
#395
Hello Zayed,
Thanks for the parts numbers for the Sports brake caliper set.
I am currently thinking of replacing my standard brake calipers on my w204 C200 CGI with the above sports brake package. Questions is are there any other parts that I need to get in order to complete my brakes upgrade exercise?
Thanks for your advice😊
