Old 06-16-2015, 01:38 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Steering and Suspension
Print Wikipost
OFFICIAL W204 Lowering Spring Thread - Post Pics of Eibach Pro Kit, H&R Sport and SS
Old 04-23-2009, 04:54 PM
  #76
TB5...'s Avatar
2009 C300 4Matic
beautiful car man... can we get a close up of those wheels and tha painted center cap.
def need to lower my ish... you dudes are making me jealous!
Old 04-27-2009, 05:35 PM
  #77
Krytech's Avatar
2014 Ghibli S Q4 & 2008 C350
To those of you who have the H&R coilovers, do you know what the minimum lowering height is? I know the descriptions says 1", but that is their generic description and they say it varies from car to car.
Info on any other coilovers would be great too.
I'd like to know if you can install the coilovers but leave your ride height close to stock? I wouldn't mind lowering it 1/2"-3/4" or so, but it would be nice to raise it back to stock (or close to it) in the winter.
Old 04-27-2009, 06:19 PM
  #78
Topchef2b's Avatar
w204 c300 Sport
H&R Sport with 19' Euro 63RS
Old 04-28-2009, 11:52 AM
  #79
MBreezy's Avatar
'09 C300 6spd MT
Esm...those wheels are 9.5 in the back? wat tires did u use, seems like u could have gone with a wider tire. those dont look like 265/30 to me....
Old 04-29-2009, 11:38 PM
  #80
G2low's Avatar
C300 and my GS300
Originally Posted by angeloxnet
Eibach pro kit installed /w 5mm spring pad in the rear
Looks good..
What wheels?
Old 04-30-2009, 01:47 AM
  #81
angeloxnet's Avatar
15 Mercedes C400, 12 Mercedes C250 coupe
E63 rim replicas (always mistaken for C63 replicas)
i believe AMG Style VI
Old 04-30-2009, 03:39 AM
  #82
berkut_g's Avatar
W204 C320CDI
going 30mph :P
on eibach s
Old 04-30-2009, 12:47 PM
  #83
Krytech's Avatar
Where did you get those? Did you say they were 18x8 and 18x9? I haven't been able to find those in 18's with the correct offset, only the 19's. Love to hear where you got them so I can look in to them.
Thanks, looks great by the way!
Old 04-30-2009, 10:24 PM
  #84
G2low's Avatar
C300 and my GS300
IMO i think they look perfect on the car.. Id love to see them with super sports.
Anyone else on supersports?
Old 05-01-2009, 02:17 AM
  #85
angeloxnet's Avatar
I got them from a guy on my local forum mbfanatics.org "supershyguy"
not too sure where he sourced them, just showed up one day with rims in his trunk
they are 8x8.5 front and 8x9.5 rear with 45 offset i believe? cant remember
Old 05-01-2009, 03:49 PM
  #86
Esm86's Avatar
Mercedes S212 200TCDI AMG
The tires are Pirelli P Zero Nero.
Front 225/35
Back: 255/30
Yes, could go with wider tire, but i know the c63 have these dimension!
Old 05-02-2009, 04:54 PM
  #87
berkut_g's Avatar
W204 C320CDI
c63 has 235 /40 in front with 255/35 on the back that is on 18"
@ angeloxnet : greeeeet ... get replica rims and cracks on the first bump . or better yet , what happend to a friend of mine , get the midle of the wheel lose from the outside of the wheel at 200km/h.
you can imagine yourself at let's say 50mp/h losing one of your tires ? with rim and all ? ahhh ? does it sound appealing.
you are ready to spend 50 000 USD ( just a price here , ok ? ) and you can't spend 3000 USD on a decent wheel set ?
Old 05-02-2009, 06:13 PM
  #88
efx1's Avatar
C350
here's mine with H&R sports
https://mbworld.org/forums/c-class-w...ed-wheels.html
Old 05-02-2009, 08:57 PM
  #89
Esm86's Avatar
I have 19"
Old 05-03-2009, 04:18 PM
  #90
phranksmbz's Avatar
09 c300 4matic
dumb question but what are mm pads for? and how do yo know which one to get? i.e.
3mm, 5mm?
Old 05-09-2009, 11:05 AM
  #91
G2low's Avatar
C300 and my GS300
bump.. any more pics?
I want to see somemore people with super sports
Old 05-09-2009, 06:53 PM
  #92
benggolf's Avatar
2010 Prius & Miata MX5 PRHT, 2010 Toyota Venza AWD, 05 C55 AMG, Yamaha 1100 Custom, Honda 250 Reflex
3mm, 5mm?
If you are changing springs, you basically have to install the new springs first, let it settle and measure how much lower you want the rear end to sit and buy the right spacer.
Of course, you must determined the thickness of the original spacer on your car when you swap your springs to know how thick or thin of a spacer to go.
Hope this helps.
Old 05-10-2009, 11:06 AM
  #93
angeloxnet's Avatar
to each is own, there are some decent quality replica's out there, replica doesnt mean replica quality, it's still a wheel produced in the same fashion and same quality just a "replica" of an actual wheel design.
I've TRACKED my rims, and they didn't "fall off", nor do i have any cracks after numerous (unavoidable potholes), Not to sure what happened to your friend and sorry to hear that, but with 5 bolts i just dont see how a wheel can "fall off" also I ask myself how often do I go"200km/h+"
Old 05-11-2009, 04:47 AM
  #94
phranksmbz's Avatar
09 c300 4matic
Hope this helps.
So mm pads are spacers? nothing more correct?
Old 05-12-2009, 03:50 PM
  #95
berkut_g's Avatar
W204 C320CDI
i've started searching for the best coilovers for my C . so , what should be the best for most driving onroad and twice a year on track .
D2, H&R, bilstein ? ? ?
thanks
Old 05-12-2009, 05:07 PM
  #96
Derspeed's Avatar
X3 and 2012 C coming soon
thanks
Do you want to adjust the rebound and damping or just the height? Personally, I would avoid D2s or anything that is not Bilstein, H&R and KW.
I know Bilstein has the PSS10 kits for our cars, but I wonder if they will have the B14 coilover kits that are similar to the available H&Rs.
Old 05-13-2009, 06:09 AM
  #97
berkut_g's Avatar
W204 C320CDI
i just want height adjustment . for the others its really difficult to get the setup just right. so factory rebound and damping and only height adjustable.
also i would like something in between 20 and 50 mm adjustable .
Old 05-13-2009, 06:12 AM
  #98
berkut_g's Avatar
W204 C320CDI
what i found at bilstein :
BILSTEIN
009211BILSTEIN - B14 PSS
Threaded Suspension (height adjustable) Gas Pressure, Conditions see certificates, For vehicles without electronic suspension control Fitting Position Front Axle, Lowering 30-50 mm, To axle load 1110 kg Fitting Position Rear Axle, Lowering 30-50 mm, To axle load 1225 kg
there is also
009212BILSTEIN - B16 PSS10
Threaded Suspension (height adjustable), Mechanically adjustable shock strength, Mounted Adjustable Gas Pressure, Conditions see certificates, For vehicles without electronic suspension control Fitting Position Front Axle, Lowering 30-50 mm, To axle load 1110 kg Fitting Position Rear Axle, Lowering 30-50 mm, To axle load 1225 kg
but it is also sock adjustable and i don't what that.
Old 09-09-2009, 04:40 AM
  #99
kevin.vernal's Avatar
2012 C63 ///AMG coupe
hey guys im trying to drop my 09 C300 w/ h&r super sport spring cost $290... i have the 19' euro23solo rims already. MB dealership charging me $800 for labor and some $100 cause they gona do some alignments... is that a good deal or i can just go to any repair shop? help me pls thanks.
Old 09-09-2009, 11:26 AM
  #100
bigigg's Avatar
14' CLS550
H&R sports 5mm rear spring pad on 19" asantis.. 9.5 rear 8.5 front
Quick Reply: OFFICIAL W204 Lowering Spring Thread - Post Pics of Eibach Pro Kit, H&R Sport and SS
