Wheel Information Thread
Old 12-12-2010, 07:41 PM
fastlanetl's Avatar
2007 E350
Will 19x8 5x112 +32 Offset and 19x9.5 5x112 +40 Offset Fit the w204 C300?
Old 12-12-2010, 09:06 PM
ZeroSeVen's Avatar
Mercedes Benz C300 Sport
You may encounter problems with this offset... I suggest go with a 45+ or higher offset on the front and 50+ offset or higher for the rears. I have 19" inch wheels with a 45 offset on the front paired with 235/35/19 tires and lowered with super sports and with that set up I only have little clearance left between my fender liner and tires.
Old 01-30-2011, 11:17 AM
navyjetmech's Avatar
c300
I want the same size wheels and tires on all four corners. I have been searching and seems almost everyone is running a staggered setup. I don't want my wheels/tires to stick out. I found a pic of one person running 19x8.5 with 235/35 tires it looked good. Is anyone else running the same size on all four corners? I would like some info and pics if possible. Oh I am not lowering the car at any point. Thanks in advanced for your help
Old 01-30-2011, 11:26 AM
Sportstick's Avatar
Another round of ICE
I see this is your first post, so welcome and here is a thread I posted a while back. I am not at your 19" wheel size (I value performance over style where they conflict), but check out carrying over the original 17" staggered size tires onto the same size 8" wheels at all four corners. They do not stick out because the offsets are compatible with the original intent. And, I, also, have no plans/desire to lower the car.
https://mbworld.org/forums/c-class-w...g-17-reps.html
Also, if I've interpreted your screen name correctly, thank you for your service!
Old 01-30-2011, 03:45 PM
c300
That looks good. I was looking at that style of wheel. I was on the fence with staying with the 17's for the same reason you did. I think I will ,but I am going to use the same size tire on all four. My dealer installed the same size tires on the OEM wheels when I bought my car. I am a freak when it comes to rotations. I am not a fan of buying new tires every 30,0000-40,000 miles. And you're welcome I am proud to serve.
Old 02-01-2011, 10:52 PM
denot's Avatar
C200 CGi
Guys, what tyres should I get for this wheels?
Enkei GTC01 STAGGERED
Size:
(2) 19x8.5
(2) 19x9.5
Offset: +42
Bolt Pattern: 5 X 112
Thanks heaps!
Old 02-02-2011, 03:00 PM
  #32
ZeroSeVen's Avatar
Size:
(2) 19x8.5
(2) 19x9.5
Offset: +42
Thanks heaps!
You can go 235/35/19 front and 265/30/19 rear with Nitto INVOs or you can also do 225/35/19 front and 255/30/19 rear with Toyo Proxes
Old 02-02-2011, 05:01 PM
  #33
Spec_Davis's Avatar
W204 Color: 090 / 1999 Honda Civic EX / 2003 Acura TL
You can do Falken 425 235/30/r19 fronts n SP Max 255/30/r19 rears. The only time it rubs is with a load of 3 people plus I have coilovers.
Old 02-17-2011, 01:02 PM
  #34
slkrks's Avatar
slk350/glk350/c300
Has anyone put OEM 18" c63 wheels (not replicas) on a C300 4matic successfully?
Old 04-25-2011, 01:21 AM
  #35
Mixedfruits's Avatar
E63 Black on Black
what do you guys think
19x8.5 ET43 front
19x9.5 ET53 rear
with h&r supersports
and be able to take canyon runs without much rubbing but also agressive for shows,
or is it not possible to have the best of both worlds?
Old 04-25-2011, 08:38 AM
  #36
skratch77's Avatar
2005 E55
Hey guys first time over here.I have a set of F14s made for an E55 w211 with
245/40/18 in the front and
275/35/18 in the rear
I dont know the offsets but I did an 8.5 in the front and a 9.5 in the rear.
Do you think I could get these to run?
The wheels will be here next week and I dont know the exact offsets.
Old 02-23-2012, 02:58 PM
  #37
garrett_wong's Avatar
c300
i am so sorry, I'm currently in the market for wheels. i was looking at 18 by 8.5 all around et 40. would they fit the rear??? looking around the forums and everyone seems to have 50+ this would help me out a lot!!! thanks guys and gals!
Old 02-23-2012, 03:20 PM
  #38
Matt_Eurojerks's Avatar
w204 C300
You will be fine.
Old 03-20-2012, 07:53 AM
  #39
ltcinf's Avatar
2010 C350, 2011 BMW 328xi
Ok--reading through these posts trying to decide what kind of offset i can do to my car for a flush look. I have a 2010 C350 with the factory AMG 17" wheels with Conti DWS 235/45ZR17 front and 255/40ZR17 in the rear. what additonal spacing should I put on the front and rear to get a flush appreareance?
Old 04-19-2012, 11:02 PM
  #40
bobyu's Avatar
C250 coupe 2012
Hey guys i talked to one of the dealership that sells VMR wheels and they suggested this specs to have the "flush" look.
what do you guys think? For now i am not planning to lower my car yet.
V718's
19x8.5 +45, 19x9.5 +45
235/35/19, 255/30/19
Kumho Ecsta SPT tires
Old 04-19-2012, 11:07 PM
  #41
mhad2480's Avatar
2011 C300 Sport, 2007 Nissan Titan Crew Cab
V718's
Just installed the same wheels on my ride. Fronts look really good, the rears on mine poke a little, but I went with a wider tire. You should be good. I got the gunmetal rims on my iridium silver 300. Looks really good to me.
Old 04-19-2012, 11:09 PM
  #42
bobyu's Avatar
C250 coupe 2012
oh awesome! could you post some pics for me? Really really want to see it
Old 04-20-2012, 01:37 AM
  #43
mhad2480's Avatar
I'll try to get some pics posted when I get home this weekend.
Old 04-23-2012, 05:11 AM
  #44
mfkl2's Avatar
2012 c250
okay....so ive just gone through this whole thread and im still lost...
i just bought a '12 C250 sport and it came with 17"s...im looking into wheels and i want 18" up front and 19" rear...and im not planning on lowering or adjusting my springs in any way. do you think im better off with 18s all around? will i be sacrificing ride quality? how far can i go with the offsets or is that personal preference? any help will be appreciated...
Old 04-23-2012, 08:12 AM
  #45
Cleanbenz's Avatar
2010 E350
V718's
Running the same wheels specs but different tire sizes on V705's
On coils it'll look like this
Old 05-06-2012, 11:19 AM
  #46
hwpaints's Avatar
c180 coupe
will this fit with out rubbing, on a C coupe 204
rear 245/30/20 et 40 or shaved 45
10x 20 inch
front 225/30/20 et 35 or shaved 40
8.5 x 20 inch
my wife is killing me when it rubs, i try now 245/30/20 et35 in front en rubs back 275/30/20 et40 rubs also
is it enough whit 245 in the back and 225 in the front they can shave 5mm of the wheel
thanks for answer
Old 05-06-2012, 06:59 PM
  #47
mhad2480's Avatar
Sorry it took me so long to get these pics posted for 'ya. I've been super busy the past few weeks. Quick pics so they're nothing great, but hopefully they give you an idea of what to expect. The center caps didn't fit on the front w/ the dust caps so I had to modify them, but haven't put them on yet. Got different caps anyway. Going Tuesday to swap out rear tires also. These pics are w/ 275 rears, going to switch to 265's. It's weird, rubbing on stock height but only on the passenger side. Hopefully won't be rubbing anymore.
Attached Thumbnails Wheel Information Thread-vmr-013.jpg   Wheel Information Thread-vmr-014.jpg   Wheel Information Thread-vmr-015.jpg   Wheel Information Thread-vmr-016.jpg   Wheel Information Thread-vmr-017.jpg
Old 05-18-2012, 09:46 PM
  #48
rtblusiewicz's Avatar
C350
i was wondering if any one could hlpe me out i have a c350 and wanted to get rims and was wondering if these will fit
http://www.ebay.com/itm/19-SPORT-GRA...16728150922151
Old 05-18-2012, 09:53 PM
  #49
Cleanbenz's Avatar
2010 E350
They will be flush in front and slightly poke in the rear at stock height. On coils they are perfect. Go for it!
Old 05-19-2012, 06:19 PM
  #50
C350
wheels
by poke out in the back how far i kinda like the flush look and if they are coming out a bit in the back how would i be able to lower the vehicle wouldnt it just rub on the wheel wells? thank you for all your info
Quick Reply: Wheel Information Thread
