Transmission service done, but ........
Old 05-09-2012, 04:39 PM
  #51
hpatel44's Avatar
2008 C300 Sport
Well I couldnt bring the car into the dealership until the afternoon so maybe that is the reason they suggested to leave it one day. Besides changing the filter and the add new oil (~9.5 quarts) I see that they should also install new overflow pipe and replace pan bolts.
Old 05-09-2012, 05:42 PM
  #52
Super Moderator
Glyn M Ruck's Avatar
If your car is fitted with the new pan & spill tube it is not necessary to do that again. I would not disturb everything again if it has a new filter either - the filter will be fine. Just get the fluid out of the transmission pan & TC & get a nice new charge into it & be done with it.
The revised pan & spill tube:
Old 05-10-2012, 03:08 PM
  #53
playstrings's Avatar
93 600SL, 09 C350
If this is a side topic , let me know... last week I was under the car and noticed some tranny fluid not really dripping but just lines like their was a very small leak... Took it in under warranty ... OH that is normal ... WTF ??? They called it sweating ?? Any of you ever see or hear of this ? Reading your stories I wonder if all dealers are just Crooks ..
Talked with a former owner... at 60,000 mi they had to do a seal (small O ring) on their leaking transmission ... $1500...
Old 05-10-2012, 06:07 PM
  #54
Super Moderator
It should not sweat. Tell them to fix it!
Old 05-12-2012, 06:11 PM
  #55
Sportstick's Avatar
Another round of ICE
Originally Posted by Glyn M Ruck
Here is the WIS 722.9 Service document & method. Very early 722.9 transmissions had no TC drain - Does not apply to W204.
We will be launching the MB World Wiki shortly with all this info.
Glyn,
I just checked last year's repair order for my wife's 2005 W211 E3504MATIC. I also had only 5 quarts of fluid at the 39,000 mile fluid replacement. Do you know what model trans (5 speed) is in this vehicle and if it has the same requirements you have been discussing?
Thanks.
Old 05-12-2012, 06:32 PM
  #56
hpatel44's Avatar
2008 C300 Sport
Hi,
Just got my car back today and can confirm that per the receipt they used 10 qts per the re-work. They did not charge me more. I am glad after the useful information from this forum my dealership was very cooperative and did the job. Thank you all!
Old 05-12-2012, 09:23 PM
  #57
Super Moderator
Originally Posted by Sportstick
Glyn,
Thanks.
SS ~ The 722.6 5 speed transmission fitted to the W211 has no TC drain. If fluid was good you can get away with half change or do a 14 quart flush. You have Wiki access. I have posted the flush procedures under 203 & 209 sections.
Old 05-12-2012, 09:32 PM
  #58
Sportstick's Avatar
Thanks! Next time around, I will have the full flush performed.
Old 05-13-2012, 07:38 AM
  #59
Super Moderator
Even in a 722.6 I like a full change but it does not work it's fluid as hard as the 722.9 does & is a less fussy transmission.
Old 05-13-2012, 09:44 AM
  #60
Sportstick's Avatar
...& is a less fussy transmission.
Thanks again! Good to know! Odd that this would wind up in my wife's car!
Old 05-14-2012, 12:37 AM
  #61
royruan's Avatar
C300 Luxury
Lucky you
Originally Posted by hpatel44
Hi,
Hi haptel44,
Good to hear that. Lucky you. At least, your dealer had guts to admit their mistake and redid it right.
Unlike the "stealer" I went to, they just tried to cover-up with a load of crap.
royruan
Old 05-14-2012, 03:00 PM
  #62
sudhanshu3's Avatar
c300
Quick question guys.... Is there a time limit for tranny flush or just mileage limit of 39K. My car is almost 4 years old and at 33K miles. Should I wait till 39K?
Old 05-14-2012, 03:27 PM
  #63
Super Moderator
I think the time trigger is 10 years in ROW. I would wait
Old 05-16-2012, 12:27 PM
  #64
Boris0126's Avatar
2009 C-300 Sport
Playstrings my car had the leak too and i took it to one dealership and they said that the car was just sweating and I'm WTF i never heard of that but then i took it to a different one and they said that had to change the seal on something i can't remember now cause i don't have the invoice with me, but tomorrow im bringing my car to get a transmission oil change and I have printed all the papers possible that I would need to explain to the service advisor cause they keep telling me that they dont drain the torque converter and transmission service is $475+tax. Glyn M Ruck thanks for all the info and now let's see how it goes with this dealership!
Old 05-16-2012, 02:25 PM
  #65
Domm's Avatar
'08 Mercedes C300
Last I checked, sweat comes from glands to lower body temperature. Not from gaps in a seal that is used to PREVENT leaks.
Old 07-11-2012, 03:57 PM
  #66
Super Moderator
johnand's Avatar
2007 C230SS; 2014 ML350 BT
Sorry I missed this thread before. I can't get over how many of you are having such issues with the dealers doing the 7G service properly. I just checked, and the WIS document posted in my service thread, is STILL the current WIS document. I have an active WIS.net account. I don't have access to Startek, for the "current bulletins" and such. But, I do have an acquaintance that does, and there are no current bulletins stating to NOT change the fluid in the torque converter. So the dealers that are stating us such are lying. As you can see by the WIS document, draining the converter was added in April of 08. So, the dealers have had more than enough time to read the updated WIS documents. They are REQUIRED by MB to perform ALL repairs and services to the letter of the WIS documents. All MB techs have access the WIS. I think we need to have people filing formal complaints to MBUSA when the dealers are not following WIS procedures. The 7G is too damn expensive to repair for incompetence like this.
OK, rant off
Old 07-11-2012, 05:24 PM
  #67
Ben'sBenz's Avatar
2009 C300 Luxury P1 w/Multimedia, Arctic White
Johnand, any comments on this post?
https://mbworld.org/forums/c-class-w...fferences.html
Old 07-12-2012, 05:50 AM
  #68
Carsy's Avatar
2007 W204 220CDI Classic Sedan
As an aside , those servicing their own 5 speed ATM's will find that they will drain an extra 1.5 litres of fluid if they leave the system draining overnight or for an extended period.
I drained a total of 5.75 litres over an 19 hour period which was 76% of the total fluid ( 7.5 litres)in the system.
So if you are not doing a flush an extra 20% if drained overnight, is worthwhile.
Old 07-12-2012, 12:39 PM
  #69
bradtj's Avatar
C350
This is BS. On separate post I was inquiring about need for 40K transmission service on a lease car soon to be turned in. As an auto enthusiast and engineer I wanted to do the right thing although I think this service and brake fluid change every 24k is overkill aimed at extracting $$ out of customer wallets. This apparent confusion over 'correct' service reinforces my feeling that this service is lightly regarded by MB dealers. I personally think the 'half-+++ed' service (partial drain)described is pointless with potential to create more problems than help. I don't think it should be our job to monitor service practices and become involved in a war of service bulletins in the hope that maybe our cars will be properly serviced at high cost.
Very dissapointed in MB approach. JMHO
Old 07-24-2012, 04:49 PM
  #70
kevink2's Avatar
2004 Mazda6, 1993 RX7
Jim - If your car W204 has a 7 speed transmission it has a TC drain. Only W204 models without are diesels with the old 5 speed.
MBUSA & many dealers are clueless.
I have provided the global WIS document on servicing the 7 speed. Your dealers just lie to people.
Fortunately there are some that do the job correctly.
Well, I'm still overseeing service to the C300 (purchase mid summer '08), even though it's more my ex's than ever after recent, amicable split.
She dropped if off for the 7 spd oil change. I emphasized that the TC must be drained. I called SM (who used to be a tech there) at dealer. He looked at the same two wis documents I got here from Glyn. He said they rotated the engine and looked for the drain screw after removing the rubber case plug .... no drain screw was seen.
He said it's not that unusual for a 722.9 not to have a TC drain plug screw. He even interpreted the general wis document, line #6, column #3, to be conditional regarding the TC drain plug: "Vehicles with drain screw on TC, except on trans # 722.93" implying that some vehicles don't have the drain screw on the TC, according to SM.
He also noted that some tech's don't want to do it, as it's impossible to prefill the TC in place, and you would be starting the trans with no oil in the TC. True?
He may have a point if the TC housings varied, with and w/o drain plugs.
This car is a 4Matic, fwiw. Glyn, are you sure enough about this for me to challenge the dealer to redo it while I observe; no drain I pay labor.
Kevin
Old 07-24-2012, 05:24 PM
  #71
Super Moderator
johnand's Avatar
Kevin,
See my last post in this thread: https://mbworld.org/forums/c-class-w...fferences.html
I ran AkaSigFreaks VIN through CURRENT WIS and EPC net, and it lists a valid part number for drain plug and WIS documents say to drain the torque converter. It is my understanding from talking to the lead tech at my local dealership, that EPC should be dead accurate. It uses engine and transmission serial numbers when inputting a VIN. If there is a change mid cycle, the affected serial numbers are updated in the database.
If you would like me to run your VIN through EPC and WIS as well, just PM me. Being yours is a 4 Matic, and you say it is a 722.93 (Eric's was a 722.999), there may be a difference.
Like I have said before, the drain plug in the torque converters are VERY easy to miss.
Kevin
Old 07-24-2012, 05:39 PM
  #72
kevink2's Avatar
Originally Posted by johnand
Being yours is a 4 Matic, and you say it is a 722.93 (Eric's was a 722.999), there may be a difference..
Thanks for the quick reply. The 722.93 was not our trans#, but was a model mentioned in the bigger pdf from Glyn.
Also, how do you put the new TC oil in?
And, was there a part# change in TC's around 2008?
Old 07-25-2012, 01:16 PM
  #73
kevink2's Avatar
MBUSA is owned by Benz but a separately registered Corp under US law. They have a history of irritating the mothership in Stuttgart.
Here is the WIS document on how to drain the converter - simple! Please note that when they talk about a drain on the 722.6 they are talking pre 1999 before it was removed.
All 722.9 transmissions fitted to W204 have a TC drain.
https://mbworld.org/forums/attachmen...-converter.pdf
When this link popped up a WIS proceedure to remove the TC drain plug, it showed a different bell housing, vs the other WIS trans drain proceedure link. Is this significant?
Old 07-25-2012, 05:42 PM
  #74
kevink2's Avatar
Just got off the phone with the local dealer parts guy. The techs have to get filters, gaskets, etc for the trans + TC oil change from the parts counter.
He looked up the part number for the torque converter (TC) for her 2008 C300 4MATIC. It's 001 990 11 17, and he said the pic showed a drain plug, and he thought the TC was for all W204's . He also said they have never sold a plug to the techs (reused old one?), and he thinks they always use about 5 Qts of oil.
Old 07-25-2012, 05:56 PM
  #75
Super Moderator
That link goes to the VIN decoder. We are having link & pic problems on the forum. Bell housings change with engine application. Access is the same in all bell housings. Rubber plug.
All W204's TC have a drain. Only old S Class with 722.9 did not. If you want to reuse the plug you need to use a sealant on it. If you saw a new one you would understand. John can verify. He used a new one.
5 quarts is just a pan change. The TC itself hold 4 Quarts+.
Quick Reply: Transmission service done, but ........
