Strange engine temperature gauge variations (Video inside) Any ideas?
Old 07-19-2015, 03:29 AM
Fadijzn's Avatar
Mercedes c280 w204
Has anybody known the solution for the problem???it started happening 2 days ago and it's driving me crazy!
I did the air flap runner repair on the intake manifold and 2 days later this started happening..
Help!!!
Old 07-19-2015, 06:09 PM
Big Daddy's Avatar
C220 CDI SLK 200
Help!!!
Replace your thermostat
Old 07-23-2015, 01:58 PM
Fadijzn's Avatar
Mercedes c280 w204
Update...
I checked the car again and it turned out that the fan module was broken..
I replaced it and now everything is perfectly fine
Old 03-10-2016, 07:32 AM
calkong's Avatar
c300
im having the same problem with my w204. where is this fan module located???? is it just the radiator fan motor??
Old 03-19-2016, 12:30 AM
calkong's Avatar
c300
fixed the problem, just replace the fan motor. cost me $90 for a used one on ebay. it came off of a 7k mile e class. which ir practically brand new.
Old 08-23-2016, 10:27 PM
Simeun Kandic's Avatar
mercedes c300
mine is doing the same thing have you found out whats causing this
Old 12-01-2016, 04:31 PM
  #32
bakrtweet's Avatar
C200 2010
Hi everyone
I have the same problem with other associated problems.
First the temperature gauge is doing exactly as shown on the video,what's more, it sometimes moves in a crazy way up and down till it reaches the zero. This is always associated with a one or two jerks, not always happening!
I checked the error codes and got two errors, one is P033631 Crankshaft sensor malfunction and the other is P011927 Coolant temperature sensor!!
I replaced both, but still getting the same and suddenly I got check engine light on my OBD
Any help?
Old 02-10-2018, 11:19 AM
  #33
Arnold Kalemi's Avatar
mercedes benz
I have an e class w212 and the temperature of my car goes from 90degres to 50 or sometime it goes to 100 and than falls down. Before this problem i changed my thermostat because i had problems with my ac so my thermostat is new. I went to the official mercedes benz about this temperature problem but they didnt know this problem so they told me to buy a new thermostat. Anyone can help me because mechanics in my country are not very good some say me that my pomp of water is the problem others tell me other thing and i am very stressed and dissapointend from my mercedes! Thank you
Old 07-07-2018, 12:38 AM
  #34
teresa88's Avatar
2008 c 300
Originally Posted by robertboone2
How did you know it was the fan control module versus the temp sensor?
I have a 2008 C350, with the following symptoms:
coolant warning, temp needle going up and down, a/c blowing but no cold area.
This is happening to my car, did you replace the fan module? Thanks in advance
Old 07-26-2018, 07:58 PM
  #35
RJelley's Avatar
'08 C350 | '14 GL450
This might be a dumb question but are you guys talking about the fan in the footwell of the passenger or the main radiator fan?
Old 10-26-2019, 06:56 PM
  #36
Steveng_2001's Avatar
2014 Mercedes-Benz ML350 4-MATIC | 2007 CLK350
Anyone find a definitive solution? ¯\_(ツ)_/¯
I have a 2007 CLK350 with the same symptoms—coolant warning light and temp gauge quickly fluctuating up and down. Happens occasionally and it's difficult to reproduce. When it does happen the car does not seem to be overheating.
Has anybody with the same issue actually solved it definitively? ​​​​​​I​t's great to get lots of opinions (temperature sensor, fan module, thermostat, etc.) but it would be really nice to hear from someone who found a definitive solution to fixing this.
Old 04-10-2023, 10:56 AM
  #37
MMCC's Avatar
2010 C350 4Matic
Just wondering if you had any luck yourself?
My 2010 C350 (W204) issues:
- High Temp indicator coming on, even though the engine temp is normal.
- Sometimes the engine temp fluctuates too high even while conservative driving.
I replaced the thermostat which fixed the irregular high over speeding fan and not blowing hot enough heat during the winter.
Still the temp indicator comes on for no apparent reason. Running the A/C doesn't seem to affect it yet. Although when it's warmer outside the temp seems to creep up then back back down, high temp icon comes on and fan runs more.
My next step is to replace the Coolant Temperature Sensor in hope this may help, but who really knows....as no one else seems to know either. Strange!
Old 04-10-2023, 04:03 PM
  #38
Resolved in my case
At the end of the day after replacing two sensors and the thermostat it came down to having to replace the entire fan unit. Even though the fan appeared to be working it wasn't functioning properly and doing the job of keeping the radiator at the proper operating temperature. Hope this helps.
Quick Reply: Strange engine temperature gauge variations (Video inside) Any ideas?
