ECO Start/Stop
I don't get it...so why would the ECO function be bad in "start/stop" traffic. The engine starts up the microsecond you take your foot off of the brake
There is absolutely nothing wrong with the system...its saves gas and improves economy. I have not had one problem with the system. True, there are conditions that have to be met for the engine to shut off, but for the most part, I get increased efficiency
'08 C350 Sport
I didn't drive in stop/start traffic that day so couldn't say much from personal experience. As an average consumer, if someone comes up and tell me that my car will stop and start at stop light, I would have that concern. Yep it is kinda baseless I know
I asked my service advisor at Smythe European and his answer is "every restart uses the starter". http://media.daimler.com/dcmedia/0-9...0-0-0-0-0.html says starter motor is redesigned ... eight times longer life ...
If you read the description closely, it does not say it uses the starter, but a direct start?
I was told by my SA it doesn't use the started, again as someone mentioned, like a golf cart
C300 2013
i got it, in my C300 2013 and i love it, ( 11 184 miles ) as for now.
i have an average of 32 Mpg , also if you do not press completely on the brake , the car won't shut down.( only on green ECO light ).
if you don't like it simply turn it off,
Other then that , nice upgrade from my 08 i had before.
#33
[QUOTE=sege;6043679]If it was as seamless as say the Toyota Prius in restarting it would be fine but mine shudders and is not at all sophisticated. Luckily for some reason it has stopped working and at my last service I instructed them to not fix it! [/QUO
Well I have just had the last service before the warranty expires and they tell me they found the battery in the boot (Auxiliary) had failed and that is why the ECO Stp Start wasn't working. Apparently it doesn't throw a code but now its back.
#34
2013 C300 4matic Sport
There are a bunch of inputs for this system. The criteria must be met for the "ECO" (in dash, not button) light to turn green and the system to be active. Those inputs are:
-engine running @ operating temperature
-hood is closed
-vehicle had to have gone over 15mph in this key cycle
-outside temp
-in cabin temp
-battery voltage
-air conditioning demand
-hood is closed
-outside temp
-in cabin temp
-battery voltage
#35
At least that is my understanding.
#36
2019 911 GTS / 2016 X3 / 2015 E63s / 1993 RX-7
Firing a single spark plug for a piston that is near TDC and then firing in the proper order will start the engine without a starter.
#37
You do not need a starter to start the engine if the ECU knows where the pistons are,and which one to fire the spark plug / add fuel.
Irrespective. When the car starts again from an ECO stop you can clearly hear the starter motor cranking the engine.
